Tempature when not in use
Postby CasioJones » Sun Sep 25, 2011 10:29 am
I have noticed a few times now that for some reason after using dvbdream/dvbviewer (temp regular around 25-32c) , the devices temp goes upwards at the moment it's at around 38c .
Unfortunately i do not have a thermal probe - this reading is being read by a cheap indoor thermometer.
This has been tested with laptop (xp) - media pc (windows 7) & my own pc (windows 7 64bit).
I just altered the settings to release LNB after use in dvbviewer. I doubt it's normal behaviour for it to do this. After all if i unplug it & re-plug it in - then temp drops to ambient room tempature .
Will edit in morning if the temp drops during the night. But i doubt it.
Hopefully it's a minor bug that can be fixed.
Chris
<edit>
Nope temp was still the same, after that i disconected usb/power for a mo & re-plugged back in - temp now at just above 26c
</edit>
<edit2>
Temp has eventually climbed to 30c & has remained steady at that.
</edit2>
CasioJones
Re: Tempature when not in use
Postby steven » Mon Sep 26, 2011 11:54 am
Hi CasioJones
This is because the tuner is reinit again. and you do not use it ,the demo have not start work so
the tempature goes down.
