AC Adapter Voltage
AC Adapter Voltage
Postby mjahabarsadiq » Sun Oct 30, 2016 4:49 pm
Hi Team,
I got TBS 5922 SE today from another person. The box content is missing AC power adapter. I have TBS 5990 and it's original power adapter. TBS 5990 is marked as 12 V 2Amp. I don't think I can use it for 5922 SE. Also, 5922 SE is not having any voltage marked. Can you please confirm the desired power supply for that so that I can buy one from local stores and use it? Please reply ASAP since I am not able to use 5922 SE though I got it after a long wait.
mjahabarsadiq
Re: AC Adapter Voltage
Postby crazycat » Sun Oct 30, 2016 10:10 pm
You can use from 7.5v to 12v. Any 12v/2a from STB work ok.
Postby mjahabarsadiq » Sun Oct 30, 2016 11:34 pm
Thanks @crazycat bro.. I used the same adapter that I used for 5990 which is of 12 V 2A and it is working fine!! Now all the packet loss issues in high bit rate got solved..
mjahabarsadiq
Postby mjahabarsadiq » Sun Apr 23, 2017 12:49 am
Hi friends,
I found the below item online which can convert USB 5V into 12 V. I am planning to use this to power my TBS 5922 SE so that I can avoid depending on AC voltage. Can you please confirm if I can use this item with TBS 5922 SE by looking at the specification of the item in the below link?
http://www.amazon.in/Banggood-Step-up-M ... B06XZC2HWQ
Thanks,
Sadiq
mjahabarsadiq
Postby mjahabarsadiq » Sat Apr 29, 2017 6:09 pm
Can someone confirm?
mjahabarsadiq
Postby mjahabarsadiq » Tue May 23, 2017 7:17 pm
Hello All
Can someone confirm my query?
mjahabarsadiq
Postby steven » Wed May 24, 2017 11:36 am
Not sure whether it will work as we have not tested like this ,but you can have a try
