Is 8922 slower than 6922?
Postby borhan3010 » Wed Jul 27, 2011 3:34 pm
Hi everyone
I have a question
The graphics card are a little distance from port PCI-expess. 6922 heat may damage the graphics card.
Now I wnan't know the 8922 offline download and watch the HDslower than 6922?
What is the difference in performance between 8922 and 6922? (Apart from the port)
Thanx
borhan3010
Re: Is 8922 slower than 6922?
Postby borhan3010 » Thu Jul 28, 2011 8:32 pm
Hello
Why doesn't anyone answer?
borhan3010
Postby steven » Fri Jul 29, 2011 9:10 am
Hi Borhan
8922 are use the same chip of 6922 ,so 8922 is the same speed with 6922.
the only difference is the bridge,6922 are use SAA7160ET,and 8922 are use CX23883.
thanks
Postby borhan3010 » Tue Aug 02, 2011 1:02 pm
Thank you Steven 8-)
borhan3010
Postby steven » Tue Aug 02, 2011 3:30 pm
borhan3010 Wrote:Thank you Steven 8-)
Your are so welcome.
