Problem with DiseqC Switcher(Solved)
Postby borhan3010 » Sat Oct 20, 2012 9:58 pm
Hi 2all
I have 8922 + Windows7 x64 and have a problem with 4to1 DiseqC Switcher!
I watch this 4 Satellite:
1-Hotbird 13 E
2-Yahsat 52.5 E
3-Badr 26 E
4- Eutelsat W7 (W3A) 7 E
when i use tbs viewer all 4 direction working fine and i can watch all channels, but another software viewer has problem and can't watch all 4 direction in same time!
Prog dvb: i can get just LNB1 and another direction no signal ):
DVB Draem: in this player I can'nt get all 4 direction: some times lnb 1 +lnb 4 working and some times lnb 2 and ... but never all 4 lnb not working together!
DVB Viewer: have signal but no video and no audio ):
for example when i use dvb dream, dvb viewer, prog dvb, ...
i use another viewer like smart viewer and can not get all Satellite and all Transponders
I use updated software, driver and codec! Also I use another DiseqC Switcher but problem not solving!
I have Free To Air Satellite TV and working fine! in tbs viewer also working fine...
How can i solving this problem??
ThanXX
borhan3010
Re: Problem with DiseqC Switcher
Postby steven » Mon Oct 22, 2012 9:37 am
Hi borhan3010
Can you have test with the new OEM-DVBDream:
https://hotfile.com/dl/176518909/a95803 ... 2.exe.html
and send your test report here.
Postby borhan3010 » Wed Oct 24, 2012 6:23 pm
Hi steven
I downloaded the new version of dvb dream 2.2b and new release driver and WOW its OK
ALl Direction now working fine and remote control also working after logon after hibernate
ThanXX VERY VERY much my friend
borhan3010
Re: Problem with DiseqC Switcher(Solved)
Postby steven » Thu Oct 25, 2012 9:44 pm
Hi borhan3010
You are welcome and thanks for your update. :)
