Source code for TSReader_BDASource_TBS8922.dll
Postby opieant » Fri Aug 03, 2012 9:25 am
Hi. I've purchased a TBS8922 card and would like to be able to start TSReader from a command line. Can you please consider making the source code available for TSReader_BDASource_TBS8922.dll? I would like to add command line support to the code myself since it isn't supported yet. Thank you.
opieant
Re: Source code for TSReader_BDASource_TBS8922.dll
Postby steven » Thu Aug 09, 2012 2:32 pm
Hi opieant
About the support for TSReader command line we are not supported now,but
when we have time we will add it as soon as possible. :)
Postby opieant » Thu Aug 09, 2012 5:26 pm
steven,
Thank you for the reply. Unfortunately, you didn't answer my question. I know that command line isn't supported now. I asked if you could make the TSReader_BDASource source code available so I could add support for it. I would appreciate it if you could answer that question.
Thank you.
opieant
Postby starman345 » Thu Aug 09, 2012 7:36 pm
opieant Wrote:Hi. I've purchased a TBS8922 card and would like to be able to start TSReader from a command line. Can you please consider making the source code available for TSReader_BDASource_TBS8922.dll? I would like to add command line support to the code myself since it isn't supported yet. Thank you.
Hopefully Steven will make the source code available to you. In case you don't know, CrazyCats' streamreaderEx proxy source module works very well from the command line in TSReader with many cards, including the 8922
10' dish- Bullseye II c/ku
55.5W to 139W
Windows 8.1 64 bit
TBS 8922 Prof 7301 TBS 6925
starman345
Postby opieant » Thu Aug 09, 2012 9:27 pm
starman345 Wrote:In case you don't know, CrazyCats' streamreaderEx proxy source module works very well from the command line in TSReader with many cards, including the 8922
Thanks, I wasn't aware of that. I'll certainly give it a try if things don't work out with the official source module. :)
opieant
