How to use remote with DVBViewer and TBSViewer
Re: How to use remote with DVBViewer and TBSViewer
Postby ivo » Thu Apr 19, 2012 9:18 pm
After installing the latest software i still don't see the vhid-device in the devicemanager???
ivo
Postby smile » Fri Apr 20, 2012 10:48 am
Hi ivo
You have to install the VHID driver before you use the remote. While installing the card driver ,it will pop up a query window ,ask you if you want to install VHID driver.
Thanks !
smile
