Signal Lost after X hours?
Postby kenada » Sat Feb 02, 2013 2:32 am
I have installed this card into 2 different PCs and have the exact same results both times.
Both PCs are the same as in Windows 7, motherboard, CPU and Ram.
1 system has an M-Audio Card and the other system has an AGP Video Card.
Other than that they are exactly the same.
After installing the card and just the driver, install the OEM Version of ProgDVB for this card per your download page card works like a dream.
40-50% Level 100% Quality this is on Galaxy 19 97W
After a few hours I run ProgDVB again and I get no signal or I get 30% Level that will drop to 0-20%, once this starts I can't recover the signal.
I don't believe it is a hardware issue or I wouldn't get anything at all.
What would cause this? I tried updating the driver to 1.0.1.4 but same results.
kenada
Re: Signal Lost after X hours?
Postby kenada » Sat Feb 02, 2013 4:45 am
UPDATE:
As of now, TBS Viewer no longer sees the tuner card in the system.
When I start TBS Viewer I get All capable DVB Adapters are busy.
No free devices has been found.
kenada
Postby kenada » Sat Feb 02, 2013 12:38 pm
Has no one else had this problem? Why would it just stop working after having perfect signal and quality?
There are not IRQ conflicts or red falgs that I can easily see.
Any information at all would help at this point. I have googled all I know with no one talking about this issue.
My system specs:
Windows 7 Ultimate 64bit
Asus P8h6-MLE motherboard
M-Audio PCI card
i3 3.30 GHZ CPU
4GB ram
kenada
Postby kenada » Tue Feb 19, 2013 1:10 am
WHERE IS THE SUPPORT FOR THIS CARD?!?!
It has now been more than 2 weeks and no reply? Is this forum even monitored?
I bought this card and I can not get it to work in Windows XP or Windows 7.
kenada
