Solution for Mediaportal Sleep problem
Postby steven » Fri Aug 24, 2012 2:02 pm
Hi All
Some users have reported that after suspend the mediaportal server config says
no card available, but with other DVB software it is ok, such as media center.
Two ways to solve it:
1st:
Please read this topic:
http://wiki.team-mediaportal.com/1_MEDI ... _detection
This is because MediaPortal TV Server only detects tuners on startup, not while it is running. So if the MediaPortal TV Server service starts before the driver/hardware is initialised by the OS, then the tuners will not be detected.
So you need to increase the delay time.
2nd:
Stop Windows adjusting the power level for PCI Express devices, switch the power saving off.
If you are experiencing such problem, just have a try with either solution.
Any problem or feedback are welcome to post here.
Re: Solution for Mediaportal Sleep problem
Postby quick001980 » Mon Jan 28, 2013 2:41 am
For some reason i can not get my tbs6922 to work with mediaportal. My setup is a stab-hh roater with qph-031 lnb Linear to port 1 of switch and circular to port 4. mediaportal picks up the card but when I go to scan or setup roater it says I have no signal
I have the same setup working with dvbdream.
using driver 1.0.1.4
mediaportal 1.2.3
what am I doing wrong or am i missing something.
quick001980
