Channel numbers
Channel numbers
Postby bogart » Thu Jan 12, 2012 6:51 am
How do I change the channel numbers and how do i get the remote to work?
bogart
Re: Channel numbers
Postby SergioDanielG » Thu Jan 12, 2012 7:30 am
Install the last remote IR software and configure it ( http://www.tbsdtv.com/download/common/S ... ID(1.0.0.4).zip ).
Witch software are you using when you want change channel numbers?
Best regards.
SergioDanielG
Re: Channel numbers
Postby bogart » Thu Jan 12, 2012 6:20 pm
I have this version of software loaded anyway. I may have not made myseld clear in my post. By changing the channel numbers I mean when you move the mouse to the right side when in tbs viewer
it list available channels 0 to whatever. I would like to rearrange the list ie what now is listed as say 5 to be moved to 1 etc etc.
bogart
