TBS 6922 Problems
TBS 6922 Problems
Postby Mohammad » Fri Jan 06, 2012 5:57 pm
Hi.
by releasing 2 or 3 new driver for this dvb card many problem has been solved.
now with latest driver & TBS IP Data : when first freq is locked you can't change it in tbs ip data & can't switch to other freqs.
many freqs in some satellites haven't quality.
in some pc systems signal level is lock at 50% or 10% & quality of the all freqs is 0%.
for some user that needed this card for satellite internet with this driver & TBS IP Data,TBS 6922 is'n usefull now.
please fix all this problem in next version of DRIVER & TBS IP DATA.
i use TBS 8920 ( My First TBS DVB Card) for now only & only for reasons that i says at the first paragraph in this topic.
many Users Of our persian tbs support website in iran is now waiting for you & new drivers & other...
thank you for your works...
MHM
TBSTEAM.NET
Mohammad
Re: TBS 6922 Problems
Postby steven » Mon Jan 09, 2012 11:26 am
Hi Mohammad
Would you mind tell us the freqs you switch to?
Would you mind tell us the detail TP information which sat and which freqs?
Postby Mohammad » Mon Jan 09, 2012 9:01 pm
please check your inbox mr steven...
To all 6922 users : user new TBS IP v3.0.3.4 & latest driver if you have problem with your dvb card...
Mohammad
Postby steven » Tue Jan 10, 2012 10:48 am
Hi Mohammad
Got it ,will send you a reply later.
