Install
Install
Postby bogart » Sat Dec 03, 2011 7:54 pm
Everything went fine installing software or so I thought. When I try to do a scan it states No Hardware found!
In device manager I have showing TBS 6922 DVBS/S2 BDA Tuner
Only one line of entry in the manager. Have I missed something
bogart
Re: Install
Postby smile » Tue Dec 06, 2011 12:56 pm
Hi bogart
what is the scan tools you used? I just have a test with the TBS6922 own scan tool, it is work well.
thanks.
smile
Re: Install
Postby bogart » Thu Dec 08, 2011 10:21 pm
Finally got it to recognise the hardware and do a scan by deleting everything and starting again.
Pictures on SD are fine but HD is very blurred, coloured and wavy.
bogart
