manual
manual
Postby joolzg » Fri Aug 12, 2011 7:39 am
is there a manual for this card?
joolz
joolzg
Re: manual
Postby steven » Tue Aug 16, 2011 9:21 am
In the driver rar file you can see the readme file.
Re: manual
Postby Sat4all » Mon Sep 19, 2011 3:08 pm
That's an easy answer that doesn't really help.
I need the manual to find out how the card should be connected.
There is a power adapter with 3 molex connectors on one side and one connector for the card on the other side. I can not imagine I have to use 3 molex connectors to power the card.
Can someone elaborate please?
Cheers,
Michel
Sat4all
Re: manual
Postby warumnix » Mon Sep 19, 2011 5:03 pm
Sat4all Wrote:That's an easy answer that doesn't really help.
Cheers,
Michel
Hi Michel,
same case as it is explained here http://www.tbsdtv.com/forum/viewtopic.php?f=21&t=144
cheers,
warumnix
warumnix
Re: manual
Postby Sat4all » Mon Sep 19, 2011 5:39 pm
Ah, missed that one. Thank you.
So no need to connect those, except for when the PCIe bus does not provide enough power.
Cheers,
Michel
Sat4all
