tbs6984 install problem install: missing file operand
Postby ceesquared » Thu Sep 12, 2013 5:51 pm
after 'sudo make && sudo make install' I get the full output but the last output is "install: missing file operand". What missing file operand?
ceesquared
Re: tbs6984 install problem install: missing file operand
Postby ceesquared » Thu Sep 12, 2013 7:59 pm
Further to problem. If I reload Mythbuntu WITHOUT doing updates, everything is OK. It would appear that there is a change in 'install' in the latest update (11 sep 13 was when I did it) which TBS are unaware of. :D
ceesquared
