Can't install driver ubuntu 12.10 kernel 3.5.0
Postby wannabe » Fri Feb 01, 2013 10:11 am
Hello
i try to install driver in ubuntu 12.10 with kernel 3.5.0 but i can't :(
Have the same issue the last time in centos :(
root@feeder:/usr/tbs/linux-tbs-drivers# ./v4l/tbs-x86_64.sh
root@feeder:/usr/tbs/linux-tbs-drivers# make && make install
make -C /usr/tbs/linux-tbs-drivers/v4l
make[1]: Entering directory `/usr/tbs/linux-tbs-drivers/v4l'
No version yet, using 3.5.0-17-generic
make[1]: Leaving directory `/usr/tbs/linux-tbs-drivers/v4l'
scripts/make_makefile.pl
Updating/Creating .config
Preparing to compile for kernel version 3.5.0
cd <your kernel dir>
./scripts/make_myconfig.pl
perl scripts/make_config_compat.pl /lib/modules/3.5.0-17-generic/build ./.myconfig ./config-compat.h
creating symbolic links...
make -C firmware prep
make[2]: Entering directory `/usr/tbs/linux-tbs-drivers/v4l/firmware'
make[2]: Leaving directory `/usr/tbs/linux-tbs-drivers/v4l/firmware'
make -C firmware
CC ihex2fw
make[2]: gcc: Command not found
make[2]: *** [ihex2fw] Error 127
make[1]: *** [firmware] Error 2
make: *** [all] Error 2
wannabe
Re: Can't install driver ubuntu 12.10 kernel 3.5.0
Postby SergioDanielG » Fri Feb 01, 2013 10:36 am
Hi wannabe.
You must to start resolving this:
If you haven't got gcc installed, you can't compile anything.
Best regards
SergioDanielG
Postby wannabe » Fri Feb 01, 2013 12:52 pm
Thanks Sergio,
i have solved the problem xD
only use this command before the installation guide.
apt-get install linux-headers-`uname -r` build-essential subversion mercurial openssl gettext libssl-dev screen libv4l-dev
root@feeder:/# dmesg | grep frontend
[ 2.486964] DVB: registering adapter 0 frontend 0 (TurboSight TBS 6984 DVBS/S2 frontend)...
[ 2.574078] DVB: registering adapter 1 frontend 0 (TurboSight TBS 6984 DVBS/S2 frontend)...
[ 2.657709] DVB: registering adapter 2 frontend 0 (TurboSight TBS 6984 DVBS/S2 frontend)...
[ 2.741473] DVB: registering adapter 3 frontend 0 (TurboSight TBS 6984 DVBS/S2 frontend)...
[ 2.845012] DVB: registering adapter 4 frontend 0 (TurboSight TBS 6984 DVBS/S2 frontend)...
[ 2.928623] DVB: registering adapter 5 frontend 0 (TurboSight TBS 6984 DVBS/S2 frontend)...
[ 3.012423] DVB: registering adapter 6 frontend 0 (TurboSight TBS 6984 DVBS/S2 frontend)...
[ 3.096142] DVB: registering adapter 7 frontend 0 (TurboSight TBS 6984 DVBS/S2 frontend)...
wannabe
Postby SergioDanielG » Fri Feb 01, 2013 7:57 pm
Congratulations!
Best regards.
SergioDanielG
