How to know the numbers of my adapters, PCI-E TBS 6984/6220
Postby xunil2003 » Thu Dec 06, 2012 1:37 am
Execusé hurt me if I speak your language, I'm French.
My two PCI-E TBS 6984/6220 works very well.
I have two PCI-E:
TurboSight 6984 TBS (Quad tuner)
TurboSight TBS 6220 (Dual Tuner)
laurent@PC-ubuntu:~$ lspci | grep Multimedia
04:00.0 Multimedia controller: Philips Semiconductors SAA7160 (rev 03)
06:00.0 Multimedia controller: Philips Semiconductors SAA7160 (rev 02)
laurent@PC-ubuntu:~$ ls /dev/dvb
adapter0  adapter1  adapter2  adapter3  adapter4  adapter5
Of the adapter5 adapter0 to what the TBS 6984 and TBS 6220 ?
I am Linux Kubuntu 12.04 x64, I want to know how he should take to know if the number of TBS adapt my cards.
How to know the number of tuner 1, 2, 3, 4 of my cards and TBS 6984 Tuner 1 and 2 of my card TBS 6220.
How do you are?
Thank you.
Cordially.
xunil2003
Re: How to know the numbers of my adapters, PCI-E TBS 6984/6
Postby SergioDanielG » Thu Dec 06, 2012 4:12 am
Hi xunil2003.
Using dvbsnoop you can know what card is it.
dvbsnoop -s feinfo -adapter 0
dvbsnoop -s feinfo -adapter 1
dvbsnoop -s feinfo -adapter 2
dvbsnoop -s feinfo -adapter 3
dvbsnoop -s feinfo -adapter 4
dvbsnoop -s feinfo -adapter 5
But not the adapter. Adapter are enumerated from 0 to n, starting from tuner more near to the mainboard (pci-e chispset really).
Additionally, in some cases you can use udev to enumerate cards and adapters. I do this with my TBS6920 (in a few hours I'll can put an example of this).
Best regards.
SergioDanielG
Postby SergioDanielG » Thu Dec 06, 2012 7:57 am
I'm sorry. I said "you can use udev ", but I'm really using modprobe options.
This is my /etc/modprobe.d/dvb.conf file
# TBS6920 PCI-e DVB-s2
options cx23885 adapter_nr=3
You can use udev too, but I haven't got any example at the moment.
Best regards.
SergioDanielG
