I modified the bash script, it works like this.
Reinstalling the driver is made and took into account the change in the kernel "3.2.0-32-generic" to "3.2.0-34-generic".
For that it is taken into account must be before:
- Code: Select All Code
sudo make clean
sudo make distclean
Then reinstalled the driver as in my bash script
The bash script:
#!/bin/bash
echo ""
echo "+----------------------------------------------+"
echo "| Driver Installation for Linux Ubuntu TBS |"
echo "| Updated on: 01/12/2012 |"
echo ""
cd /home/laurent/pilotes/tbs-linux-drivers_v121021/linux-tbs-drivers/
echo ""
echo "sudo make clean"
echo "-----------------------------"
sudo make clean
echo ""
echo "sudo make distclean"
sudo make distclean
echo ""
echo "execute : ./v4l/tbs-x86_64.sh"
sudo ./v4l/tbs-x86_64.sh
echo ""
echo "execute : /home/laurent/pilotes/tbs-linux-drivers_v121021/linux-tbs-drivers/"
echo "--------------------------------------------------------------------------------"
#sudo make TARGET=x86_64-elf && sudo make install
echo ""
echo "execute : sudo make TARGET=x86_64-elf"
echo "-------------------------------------"
echo ""
echo "execute : sudo make install"
echo "---------------------------"
sudo make install
echo ""
echo "ATTENTION :"
echo "-----------"
echo "You must restart the pc."
echo "Once restarted please type in the terminal to check that the driver is installed correctly :"
echo "dmesg | grep frontend"
echo ""
Once your PC restarts, type in the terminal :
It will show your cards like this :
laurent@PC-ubuntu:~/bash/Ubuntu_12.04$ dmesg | grep frontend
[ 11.666116] DVB: registering adapter 0 frontend 0 (TurboSight TBS 62x0 DVBT/T2 frontend)...
[ 11.758104] DVB: registering adapter 1 frontend 0 (TurboSight TBS 62x0 DVBT/T2 frontend)...
[ 12.039262] DVB: registering adapter 2 frontend 0 (TurboSight TBS 6984 DVBS/S2 frontend)...
[ 12.129924] DVB: registering adapter 3 frontend 0 (TurboSight TBS 6984 DVBS/S2 frontend)...
[ 12.217919] DVB: registering adapter 4 frontend 0 (TurboSight TBS 6984 DVBS/S2 frontend)...
[ 12.305835] DVB: registering adapter 5 frontend 0 (TurboSight TBS 6984 DVBS/S2 frontend)...
Thank you.
Cordially.
