big problem on TBS6984 frezzing issue
Postby spacedvb » Mon Sep 24, 2012 10:38 am
I had a RU1 server runing :
Debain Squeeze latest version.
Ram 16GB
Xeon 6Core 3.80
TBS6984
Getstream_84 server with Astra
The server was runing fine, passing the last 24 hours streamer is not working as before signal is dropping from time to time.
I check the dish all wireing and change for new coax wire, .
I connect one of my STB DVBS2 Settopbox and work fine from the same dish i had this problem.
the Signal is as fallow.
Sep 23 21:26:25: [Stream:The Movie Ch]Scan CAT table:
Sep 23 21:26:25: [Stream:The Movie Ch] EMM: pid:32 caid:0x1800 private_data:
Sep 23 21:26:25: [Stream:The Movie Ch] EMM: pid:288 caid:0x1801 private_data:
Sep 23 21:26:25: [Stream:The Movie Ch] EMM: pid:288 caid:0x1810 private_data:
Sep 23 21:26:25: [Stream:The Movie Ch] EMM: pid:849 caid:0x1821 private_data:
Sep 23 21:26:25: [Stream:The Movie Ch] EMM: pid:850 caid:0x1822 private_data:
Sep 23 21:26:25: [Stream:The Movie Ch] EMM: pid:288 caid:0x1816 private_data:
Sep 23 21:26:25: [Stream:The Movie Ch] EMM: pid:848 caid:0x182E private_data:
Sep 23 21:26:25: [Stream:The Movie Ch] EMM: pid:288 caid:0x1840 private_data:
Sep 23 21:27:23: Info DVB: signal:74% snr:100%
Sep 23 21:28:23: Info DVB: signal:74% snr:100%
Sep 23 21:29:23: Info DVB: signal:74% snr:100%
Sep 23 21:30:23: Info DVB: signal:74% snr:100%
Sep 23 21:31:23: Info DVB: signal:74% snr:100%
Sep 23 21:32:23: Info DVB: signal:74% snr:100%
Sep 23 21:33:23: Info DVB: signal:74% snr:100%
Sep 23 21:34:23: Info DVB: signal:74% snr:100%
Sep 23 21:35:23: Info DVB: signal:74% snr:100%
Sep 23 21:36:23: Info DVB: signal:74% snr:100%
Sep 23 21:37:23: Info DVB: signal:74% snr:100%
Sep 23 21:38:23: Info DVB: signal:74% snr:100%
on my Bird Dog signal show up 100% signal , on my STB dvbs2 work perfectly with out frezzing this make me think problem is not on the dish our wireing .
My next test will be changing TBS quad to a new one, as i have 8pcs i buy,.
If this is the case that the TBS quad has this issue does is a new driver that I can update?
Karnel:2.6.32-5-amd64
spacedvb
Re: big problem on TBS6984 frezzing issue
Postby SergioDanielG » Tue Sep 25, 2012 2:20 am
Hi spacedvb.
getstream have a buffer parameter. Did you try modify it?
Best regards.
SergioDanielG
