No Lock from 4 input card, 2 input card works
Postby joolzg » Wed Sep 12, 2012 4:08 am
Asrock 990FX PROFESSIONAL Fatal1ty SLI/C
AMD FX-8150 X8 3.6GHz 16MB 125W Box AM3+
Installed newest drivers and get /dev/dvb/adaptor0 to 3
running dvblast on any of the 4 inputs and i get no lock, so no streaming
change to a dual+ci and i get a lock straight away on both inputs, any ideas?
uname -a
Linux encoder22 2.6.38-15-generic #66-Ubuntu SMP Tue Aug 14 17:24:44 UTC 2012 x86_64 x86_64 x86_64 GNU/Linux
lspci
00:00.0 Host bridge: ATI Technologies Inc RD890 PCI to PCI bridge (external gfx0 port B) (rev 02)
00:02.0 PCI bridge: ATI Technologies Inc RD890 PCI to PCI bridge (PCI express gpp port B)
00:04.0 PCI bridge: ATI Technologies Inc RD890 PCI to PCI bridge (PCI express gpp port D)
00:05.0 PCI bridge: ATI Technologies Inc RD890 PCI to PCI bridge (PCI express gpp port E)
00:06.0 PCI bridge: ATI Technologies Inc RD890 PCI to PCI bridge (PCI express gpp port F)
00:07.0 PCI bridge: ATI Technologies Inc RD890 PCI to PCI bridge (PCI express gpp port G)
00:09.0 PCI bridge: ATI Technologies Inc RD890 PCI to PCI bridge (PCI express gpp port H)
00:0d.0 PCI bridge: ATI Technologies Inc RD890 PCI to PCI bridge (external gfx1 port B)
00:11.0 SATA controller: ATI Technologies Inc SB7x0/SB8x0/SB9x0 SATA Controller [IDE mode] (rev 40)
00:12.0 USB Controller: ATI Technologies Inc SB7x0/SB8x0/SB9x0 USB OHCI0 Controller
00:12.2 USB Controller: ATI Technologies Inc SB7x0/SB8x0/SB9x0 USB EHCI Controller
00:13.0 USB Controller: ATI Technologies Inc SB7x0/SB8x0/SB9x0 USB OHCI0 Controller
00:13.2 USB Controller: ATI Technologies Inc SB7x0/SB8x0/SB9x0 USB EHCI Controller
00:14.0 SMBus: ATI Technologies Inc SBx00 SMBus Controller (rev 42)
00:14.1 IDE interface: ATI Technologies Inc SB7x0/SB8x0/SB9x0 IDE Controller (rev 40)
00:14.2 Audio device: ATI Technologies Inc SBx00 Azalia (Intel HDA) (rev 40)
00:14.3 ISA bridge: ATI Technologies Inc SB7x0/SB8x0/SB9x0 LPC host controller (rev 40)
00:14.4 PCI bridge: ATI Technologies Inc SBx00 PCI to PCI Bridge (rev 40)
00:14.5 USB Controller: ATI Technologies Inc SB7x0/SB8x0/SB9x0 USB OHCI2 Controller
00:15.0 PCI bridge: ATI Technologies Inc Device 43a0
00:15.1 PCI bridge: ATI Technologies Inc Device 43a1
00:15.2 PCI bridge: ATI Technologies Inc Device 43a2
00:16.0 USB Controller: ATI Technologies Inc SB7x0/SB8x0/SB9x0 USB OHCI0 Controller
00:16.2 USB Controller: ATI Technologies Inc SB7x0/SB8x0/SB9x0 USB EHCI Controller
00:18.0 Host bridge: Advanced Micro Devices [AMD] Device 1600
00:18.1 Host bridge: Advanced Micro Devices [AMD] Device 1601
00:18.2 Host bridge: Advanced Micro Devices [AMD] Device 1602
00:18.3 Host bridge: Advanced Micro Devices [AMD] Device 1603
00:18.4 Host bridge: Advanced Micro Devices [AMD] Device 1604
00:18.5 Host bridge: Advanced Micro Devices [AMD] Device 1605
01:00.0 VGA compatible controller: ATI Technologies Inc Manhattan [Mobility Radeon HD 5430 Series]
01:00.1 Audio device: ATI Technologies Inc Manhattan HDMI Audio [Mobility Radeon HD 5000 Series]
02:00.0 IDE interface: Marvell Technology Group Ltd. Device 917a (rev 11)
03:00.0 USB Controller: Device 1b6f:7023 (rev 01)
04:00.0 USB Controller: Device 1b6f:7023 (rev 01)
05:00.0 USB Controller: Device 1b6f:7023 (rev 01)
06:00.0 Multimedia controller: Philips Semiconductors SAA7160 (rev 02)
07:00.0 Ethernet controller: Intel Corporation 82574L Gigabit Network Connection
09:00.0 FireWire (IEEE 1394): VIA Technologies, Inc. VT6315 Series Firewire Controller (rev 01)
0a:00.0 Ethernet controller: Broadcom Corporation NetLink BCM57781 Gigabit Ethernet PCIe (rev 10)
0b:00.0 Ethernet controller: Broadcom Corporation NetLink BCM57781 Gigabit Ethernet PCIe (rev 10)
dmesg | grep tbs && dmesg | grep TBS
encoder@encoder22:~$ dmesg | grep tbs
[ 9.476901] tbs6982fe: module license 'TurboSight Proprietary: http://www.tbsdtv.com' taints kernel.
[ 10.670023] Registered IR keymap rc-tbs-nec
encoder@encoder22:~$ dmesg | grep TBS
[ 10.536181] SAA716x TBS 0000:06:00.0: PCI INT A -> GSI 48 (level, low) -> IRQ 48
[ 10.536188] SAA716x TBS 0000:06:00.0: setting latency timer to 64
[ 10.670105] input: saa716x IR (TurboSight TBS 6984) as /devices/pci0000:00/0000:00:09.0/0000:06:00.0/rc/rc0/input5
[ 10.670158] rc0: saa716x IR (TurboSight TBS 6984) as /devices/pci0000:00/0000:00:09.0/0000:06:00.0/rc/rc0
[ 10.671954] TurboSight TBS 6984 Frontend 0 Attaching...
[ 10.869817] TurboSight TBS6984 DVB-S2 card port0 MAC=00:22:ab:90:18:c0
[ 10.869820] DVB: registering adapter 0 frontend 0 (TurboSight TBS 6984 DVBS/S2 frontend)...
[ 10.870280] TurboSight TBS 6984 Frontend 1 Attaching...
[ 11.055658] TurboSight TBS6984 DVB-S2 card port1 MAC=00:22:ab:90:18:c1
[ 11.055661] DVB: registering adapter 1 frontend 0 (TurboSight TBS 6984 DVBS/S2 frontend)...
[ 11.056076] TurboSight TBS 6984 Frontend 2 Attaching...
[ 11.235657] TurboSight TBS6984 DVB-S2 card port2 MAC=00:22:ab:90:18:c2
[ 11.235660] DVB: registering adapter 2 frontend 0 (TurboSight TBS 6984 DVBS/S2 frontend)...
[ 11.236063] TurboSight TBS 6984 Frontend 3 Attaching...
[ 11.415647] TurboSight TBS6984 DVB-S2 card port3 MAC=00:22:ab:90:18:c3
[ 11.415650] DVB: registering adapter 3 frontend 0 (TurboSight TBS 6984 DVBS/S2 frontend)...
I can give you any info you want but i cannot get any lock from any of the 4 inputs when using this card in this machine.
joolz
joolzg
Re: No Lock from 4 input card, 2 input card works
Postby SergioDanielG » Thu Sep 13, 2012 8:19 am
Hi joolzg.
Can you post ouput of the command used to start dvblast, the output of dvblast when it's started and output of "femon -H" when dvblast is running?
Additionally, you can run "tail -f /var/log/kern.log" to see if there are some problem with your card.
Best regards.
SergioDanielG
