Ubuntu 12.04 drops device from system.
Postby tdiboy » Tue May 15, 2012 12:59 am
I've been trying to configure my 6984 with MythBuntu 12.04 (tried vanilla 12.04 too) and got the card installed fine. After installation I could run dmesg Z grep DVB and see all 4 card entries. It seems after an undetermined time (a few reboots and system updates) the card gets dropped with dmesg showing the following:
[ 6.743099] tbs6982fe: module license 'TurboSight Proprietary: www.tbsdtv.com' taints kernel.
[ 6.743102] Disabling lock debugging due to kernel taint
[ 6.782431] saa716x_core: disagrees about version of symbol dvb_dmxdev_init
[ 6.782435] saa716x_core: Unknown symbol dvb_dmxdev_init (err -22)
[ 6.782458] saa716x_core: disagrees about version of symbol dvb_register_adapter
[ 6.782460] saa716x_core: Unknown symbol dvb_register_adapter (err -22)
[ 6.782474] saa716x_core: disagrees about version of symbol dvb_net_init
[ 6.782475] saa716x_core: Unknown symbol dvb_net_init (err -22)
[ 6.782480] saa716x_core: disagrees about version of symbol dvb_dmxdev_release
[ 6.782481] saa716x_core: Unknown symbol dvb_dmxdev_release (err -22)
[ 6.782487] saa716x_core: disagrees about version of symbol dvb_frontend_detach
[ 6.782488] saa716x_core: Unknown symbol dvb_frontend_detach (err -22)
[ 6.782491] saa716x_core: disagrees about version of symbol dvb_net_release
[ 6.782492] saa716x_core: Unknown symbol dvb_net_release (err -22)
[ 6.782496] saa716x_core: disagrees about version of symbol dvb_unregister_frontend
[ 6.782498] saa716x_core: Unknown symbol dvb_unregister_frontend (err -22)
[ 6.782502] saa716x_core: disagrees about version of symbol dvb_register_frontend
[ 6.782504] saa716x_core: Unknown symbol dvb_register_frontend (err -22)
[ 6.782508] saa716x_core: disagrees about version of symbol dvb_unregister_adapter
[ 6.782510] saa716x_core: Unknown symbol dvb_unregister_adapter (err -22)
It seems (to me) that the other drivers loaded during the installation process are causing a problem as the above mentions a TBS6982.
Could someone please advise on how to fix this as it keeps happening (many rebuilds later).
tdiboy
Re: Ubuntu 12.04 drops device from system.
Postby SergioDanielG » Tue May 15, 2012 10:59 am
Hi tdiboy.
If you update your system and this update include kernel updates, you need to recomplie tbs drivers. Maybe this is the problem.
Can you try recompiling drivers and comment if your cards works again?
Best regards.
SergioDanielG
