dvblast udp problem
dvblast udp problem
Postby aerayp » Tue Feb 21, 2012 6:38 pm
I use tbs6984 board to get satellite streams and dvblast to send streams to multicast network. Unfortunately with UDP protocol I have packet loss. RTP is not useful for my system. How to solve this problem?
Thanks,
Eray
aerayp
Re: dvblast udp problem
Postby SergioDanielG » Wed Feb 29, 2012 8:34 pm
UDP protocol haven' t got flow control or error correction. If there are lossing packages maybe you have a poor signal conextion or low symbol rate. What about this?
Best regards.
SergioDanielG
Postby spacedvb » Sat Aug 18, 2012 9:32 pm
use getstream_84 download from cesbo dot com.
spacedvb
Postby ahmedramze » Mon Aug 18, 2014 7:15 am
dvblast -u -a 1 -f 10890000 -s 27500000 -v 13 -F 78 -m psk_8 -Y -U -d 239.0.0.1:1205
f- Frequency
s- symbol rate
-v LNB Voltage H=18 , V=13
-m modulation , qpsk , or psk_8 , QAM, etc.
-U mean udp with out -U will be RTP protocol (( this is your issue ))
-d the destination Multicast IP and port
ahmedramze
Postby krmlk » Fri Dec 23, 2016 3:30 am
I have similar problem. For 1-2 Tranpordereverythin seems ok withdvblast udp but after adding more transporder lose many packets
krmlk
Postby steven » Fri Dec 23, 2016 11:40 am
krmlk Wrote:I have similar problem. For 1-2 Tranpordereverythin seems ok withdvblast udp but after adding more transporder lose many packets
What about your net work environment when you test the transponder one by one if everyone are ok then should be your network issue
make sure 1Gbps
Postby krmlk » Sat Dec 24, 2016 6:05 am
all internal network already 1 Gbit also 2 LAN 1Gbit active. Every port on the Router using 1Gbit connection. All the cables cat6. Actually DVBlast is best multicast streamer IMO but because of this reason I should use unicast with mumudvb (doesnt work properly with m cards) and astra cesbo .( tvheadend is goo, too) but it is crashing very often
krmlk
