3 Cards simultaneously
Re: 3 Cards simultaneously
Postby SergioDanielG » Tue Jan 17, 2012 7:24 am
WOW! 3 TBS6984 in the same mother borar requiere a lot of power! ("lot" is subjective, it's not good or bad) Have all cards conected power cable?
Witch motherboard are you using?
Best regards.
SergioDanielG
Postby warumnix » Tue Jan 17, 2012 3:26 pm
Hi vitalizator,
it's not required to connect the power cables, please refer to http://www.tbsdtv.com/forum/viewtopic.php?f=21&t=144, and try again without the power cable connecting.
best regards
warumnix
