Installation error on OpenSuse 11.4(Solved)
Postby garry » Wed Sep 28, 2011 5:49 pm
Run v4l/tbs-x64_64.sh. All ok. But make completes with error:
No rule to make target `/tbs/linux-tbs-drivers/linux-tbs-drivers/v4l/tbs6980ctrl.o', needed by `/tbs/linux-tbs-drivers/linux-tbs-drivers/v4l/tda18271.o'. Stop.
Do you support OpenSuse 11.4 x64? How to install drivers on this system?
garry
Re: Installation error on OpenSuse 11.4
Postby garry » Wed Sep 28, 2011 8:07 pm
I found the solution - http://www.tbsdtv.com/forum/viewtopic.php?f=3&t=26
You must do it for every error.
garry
Re: Installation error on OpenSuse 11.4(Solved)
Postby steven » Fri Sep 30, 2011 9:06 am
Thanks for sharing your method. :D
