Using TBS 6984 with MediaPortal TV Server
Postby steven » Tue Jul 26, 2011 3:59 pm
Note:This review is contributed by Rhys Goodwin.
TBS Technology has been making TV tuner cards for about 5 years and they’re starting to build a good reputation amongst HTPC enthusiasts, and for good reason – as you’ll see the 6984 Quad Tuner card is a solid performer. This review will focus on using the TBS 6984 with MediaPortal TV Server.
The TBS6984 really is the grand-daddy of DVB-S2 cards! It’s a DVB-S/S2 PCI Express card with 4 tuners allowing you capture from 4 different satellite transponders simultaneously. At $249USD the price is right. That’s about $62 per tuner – considerably cheaper than buying 4 separate DVB-S2 cards and much more convenient.
TBS list the following specifications:
Receiving Frequency: 925~2175 MHz Tuning Range
Input Level: -69~23dBm
4x Advanced DVB-S2/DVB-S 8PSK QPSK Demodulator
Symbol Rates:
DVB-S QPSK: 1-45 Msps
DVB-S2 8PSK/QPSK: 2-36 Msps
Code Rates:
DVB-S: 1/2, 2/3, 3/4, 5/6, 7/8
DVB-S2 QPSK: 1/2, 3/5, 2/3, 3/4. 4/5. 5/6, 8/9, 9/10
DVB-S2 8PSK: 3/5, 2/3. 3/4. 5/6. 8/9, 9/10
I’m not going to pretend that I could explain all the technical aspects of these specs, but suffice to say this card will handle pretty much anything you can throw at it.
What’s In The Box
* The PCIe Card
* A driver mini-CD
* Infrared Remote Control
* Infrared Receiver Cable
* Power Cable
The build quality of the card is excellent – all the soldering looks clean and solid, and the components are well aligned. The bracket has labels for the tuners ‘A’ through ‘D’ stamped on it – a nice touch. The chipset consists of the following:
* 2x Trident CX24132 Dual DVB-S2 Tuner
* 2x Trident CX24117 Dual DVB-S2 Demodulator
* 2x Intersil ISL6422B Dual Output LNB Supply and Control Voltage Regulator
* 1x Trident SAA7160E PCI Express Audio/Video Capture Bridge
The remote is pretty basic; but let’s be honest, if you’re looking for a quad tuner card you’re probably an HTPC enthusiast in which case you’ll already have an advanced remote. If not you’ll need to get one! It has TV and navigation buttons, but lacks buttons for the advanced features you’d typically find in media centre packages like MediaPortal. That said, it will do just fine to get you up and running with basic TV software.
As for the driver CD, I haven’t even put it in my PC. Personally I never use the driver CDs which come with any hardware. I prefer to go straight to the web and download the very latest version. It would be nice if TBS released a white-box version of this product, which included just the card and the power cable.
TBS state that the additional power cable is only required when you need extra current for driving things like dish positioning motors and some LNBs. In general, you shouldn’t require it which is good – the less cables floating around the better when it comes to an HTPC that you’re trying to keep cool with a minimum of fans.
Installation
I’d love to go into great detail about the installation but there really isn’t much to say. The hardware side is obvious – unplug your PC and install the card into a spare PCIe 1x slot.
As for the driver,TBS keeps it simple which I really appreciate. You don’t have to run an installer (although there is one). You can simply let Windows detect the card and then tell it where to find the latest driver files and the device installs without any fuss. I wish more manufacturers would take this simple clean approach. With an installer, you don’t really know what you’re getting and what’s being changed on your system. I’m running Windows 7 x64. Once the driver is installed, you’ll see a single “TBS 6984 Quad DVBS/S2 BDA Tuners” device listed in device manager. The driver is a BDA driver, which means it conforms to Microsoft’s broadcast driver architecture so the card will be compatible with any TV software which supports BDA devices.
MediaPortal
MediaPortal is a free and open source media centre package for Windows.
You can get a wealth of information and support at the Team-MediaPortal site, but these are the basic components that you’ll need to get TV up and running with the TBS 6984. The remainder of this review will focus on the TV Server component of MediaPortal.
* MediaPortal – this is the main front-end application. You can have this installed on as many PCs around the house as you like
* TV Server – this is a Windows service which manages all TV streaming and recording. It can be on the same or a different PC to the MediaPortal application
* TV Client Plug-in – this is a plug-in component to MediaPortal which connects it to the TV Server
Once you’ve got the driver installed TV Server will detect the card. You’ll have to restart the TV Service and TV Server configuration tool if they are already running.
One thing I really like about this card is the way it identifies itself. In the Windows device manager it just shows a single device, but once you open up the TV Server configuration tool you’ll see all 4 tuners and they’re actually labelled A, B, C and D – unlike some other dual cards I’ve seen, which just show 2 identical tuners so you can’t tell which one is which.
Scanning speed is impressive – just over 6 minutes to scan 41 transponders. Both DVB-S and DVB-S2 channels are found correctly.
Now the part you’ve been waiting for – recording 4 channels at once. In fact, with MediaPortal TV Server you can record even more than that because it allows you to record all the channels on a given transponder at the same time. The TBS 6984 can tune into 4 separate transponders, so if each of those transponders carries 6 channels that would mean you could record 24 channels simultaneously! Below you can see I’m receiving 12 channels quite happily and the 6984 doesn’t skip a beat! “Just try that Windows 7 Media Center!”
The driver seems to report the signal quality and strength much more accurately than a lot of other cards I’ve seen, and also updates these quite frequently – which is great.
Channel Change Speed
The most common question I hear when discussing various TV cards with HTPC enthusiasts is “How fast can it change channels?”. There are a number of things that can affect this – system hardware, TV card, TV card driver, TV software, media codecs, etc. It also depends on where you take the measurement. The following results are taken from the TV Server logs, and indicate the time it takes for the TV card to switch channels.
Very impressive, with all tests sub-second, except DVB-S to DVB-S2 switching which takes a little longer.
DiSEqC
The TBS 6984 supports DiSEqC 2.x,it is compatible well with MediaPortal TV Server.
Conclusion
All-in-all, my only criticism is that such a high-end card should be matched with a high-end remote. I think the best solution is a white box version of the product so the user can choose their own remote.
The channel change speed tests speak for themselves; that, combined with the solid driver and excellent build quality, makes the 6984 an excellent choice for anyone looking to build or expand an HTPC. In fact, unless you’re certain you won’t need more than 2 tuners, I would say just go straight for the 6984 because you’ll end up saving money in the long run.
As for TBS support – while I haven’t needed any technical support, from what I’ve read elsewhere they seem to have a reputation of being very responsive as well as being happy to interact with the MediaPortal development team. They also make their SDK (software development kit) freely available.
Re: Using TBS 6984 with MediaPortal TV Server
Postby Shummi » Mon Aug 01, 2011 4:19 pm
Thanks for a good review
Until i read your review, i was going crasy.
but my problem was the DiSeqc in MediaPortal
Do you know when it will be solved
/Jesper
Shummi
Postby okbet » Wed Aug 10, 2011 12:50 pm
Shummi Wrote:Hi
/Jesper
There is no known DiSEqC issue with MediaPortal for TBS6984. From our testing, it's working with MediaPortal correctly.
okbet
Postby psykix » Fri Aug 19, 2011 12:07 am
If only Mediaportal supported USALS, then it would be the perfect combo.
I use Mediaportal with 3 x TBS 6981 cards and it works like a dream apart from the motorised dish on one of the tuners which is temperamental.
psykix
