TBS6984 WMC7 Declining ability to find tuner after S3 wake o
Postby himfella » Thu Sep 27, 2012 11:20 am
Replaced 2 Hauppauge Nova S+ tuners which were mostly reliable, very occasional missed recording due to "tuner was not present at time of recording" so MC7 history stated.
Upgraded to TBS6984 tuner, card ran reliably for first month then started missing scheduled recordings, during which time I reinstalled graphics/sound card HDMI drivers, reset up tuner rescanned satellite, all gave only temporary fixes. Found MC required reboot to enable tuners to be available but soon became unavailable again during playback session with scheduled recording in back ground or S3 wake to record failed due to "tuner was not present at time of recording" Windows devise manager indicated TSB6984 present and working properly.
Reinstalled W7 64bit OS, TSB6984 failed as above from outset "Service unavailable [WMC] Removed TSB6984 reinstalled Hauppauge tuners no issues since. Hoping for a software fix but have not found one as yet.
Thanks in advance for any assistance offered to help fix this problem.
himfella
Re: TBS6984 WMC7 Declining ability to find tuner after S3 wa
Postby tigercook » Thu Nov 01, 2012 3:48 am
Hi I have the same problem, I have 2 of the dvbs2 cards, the problem only occurred when I installed the second one, is it a driver problem, background scan problem or should I connect the additional power connectors. I also experience a no signal when trying to record HD although I can watch live TV OK. Any help will be great, btw latest drivers installwd wmc7 thanks Neil
tigercook
Postby tigercook » Thu Nov 01, 2012 9:07 pm
i have plugged in the additional power and changed my power setting disabling the PCIe power saving; no change tuners still unavailable, unless i reboot the machine. so is it now the background scanning or a driver problem? thanks Neil
tigercook
Postby steven » Fri Nov 02, 2012 3:04 pm
Hi tigercook
What about other player,such as DVBDream? is it ok ?
Postby tigercook » Fri Nov 02, 2012 9:57 pm
ah yes sorry i have just realised the tiered forum, i have 2 TBS6981 DVB-S2 Dual Tuner PCIe Card, thanks Neil
tigercook
