What is Reader PATH on TBSQBOX ?
Postby jpg333 » Fri Jul 12, 2013 5:02 pm
Hi all,
I try to use oscam with tvheadend on my TBS QBOX CI
To configure oscam.server I need to specify reader path name
On reader TBS3101 it's look lile /dev/ttyUSB0
is it the same for TBS5980 ? Di you know the exact name ?
Thanks a lot in advance
JP
jpg333
Re: What is Reader PATH on TBSQBOX ?
Postby TUISTERa » Tue Jul 23, 2013 4:08 am
If you press scan usb in oscam reader webpage what will be output result?
TUISTERa
