Driver Windows Tbs 5980
Postby Marco68 » Sun Nov 15, 2015 6:09 pm
Hi, waiting for someone kindly help me for the other post (Prog Dvb Tbs edition), I test accurately my Tbs box.
I noticed that the tuner sensitivity is completely unsatisfied with official Windows drivers 32 bit (actual release 1.0.3.3) but if you use Crazy Cat driver (CrazyBDA 1.0.0.2) the card performance is completely different. I can receive a lot of channels I couldn't lock with official drivers (e.g. BBC package 27,5 west) which I receive with Tbs 6922 (I guess official driver are better for pci cards).
Besides, using Crazy Cat driver I can also lock mis channel with Alt dvb (only with bda2 module with direct hw control, now 0.2.1.1239).
I hope official driver will be improved, they need to.
Regards
Marco
Marco68
Re: Driver Windows Tbs 5980
Postby crazycat » Mon Nov 16, 2015 9:50 am
i think no need :) 5980 is EOL product :) btw most long-life and reliable TBS device :) most functional/price product :)
Postby Marco68 » Tue Nov 17, 2015 12:28 am
Hi Crazycat, very pleased to read you!
I think it's a very good product with your driver, it wouldn't be without....
I' m going crazy to tune mis channel. I only succeded with Alt dvb, using your bda2 module with direct hw control, (0.2.1.1239).
Worst results with Smart Dvb (some locked others not). No mis channel with Dvb Dream. Could you help me?
Dvb Dream is a good software and I'd like to use it for multiple input stream channels.
Best regards
Marco68
Postby crazycat » Tue Nov 17, 2015 3:15 am
So ask DVBDream developer. I can provide CrazyBDA API for MIS,PLS control (for write DD BDA extension module)
Btw BDA2 AltDVB module not use direct hw control with CrazyBDA driver (but used with official TBS 5980 driver).
