Questions about the new Windows driver 1.0.2.9
Postby ccristal » Sat Jul 13, 2013 6:32 pm
Hi!
What's the changelog for the Windows driver 1.0.2.9 with respect to 1.0.2.7?
I was running version 1.0.2.8 of the driver, which was a modified version of 1.0.2.7 with the IR capabilities disabled. I requested that change because I had a conflict with my sound system remote (see http://www.tbsdtv.com/forum/viewtopic.php?f=33&t=8520). If I install 1.0.2.9, will I still have that problem?
Thank you!
ccristal
EDIT: I installed 1.0.2.9 and I still have the volume down problem. Rolling back to 1.0.2.8. Would still love to see the changelog for 1.0.2.9, though... Thanks!
ccristal
Re: Questions about the new Windows driver 1.0.2.9
Postby steven » Tue Jul 23, 2013 6:40 pm
Hi ccristal
not many change. : )
The V1.0.2.8's IR is disabled so V1.0.2.9 enable it. :)
Postby ccristal » Wed Jul 24, 2013 4:21 am
Fantastic, thanks! I'll keep 1.0.2.8, then... :-)
How about TbsCIapi.dll? I keep downloading every new version and copying it in my DVBViewer program directory, but I'm not sure whether I should keep doing it, as I haven't been able to find much documentation about this library.
What is it? Does it need to match a specific driver version, or are dll and driver completely independent from each other?
Thank you!
ccristal
ccristal
Postby Retiree » Wed Jul 24, 2013 4:07 pm
Dynamic-link library tbsCiapi. dll provides the liaison between utility (DVBDream, DVBViewer, ProgDVB, etc) and decoding CA module. For viewing only FTA channels do not have this necessary library (my experience with DVB-C dual tuner TBS6680)...
Retiree
