TBS 5980 freezes with Volume Down from my audio remote
Postby ccristal » Fri May 24, 2013 6:16 am
Hi!
Somehow, my QBOX CI (TBS 5980) intercepts the IR code for the "Volume down" key of my Yamaha amplifier's remote, and that freezes the receiver.
Is there any way of disabling the IR port of my QBOX, so I can work around the problem (apart from sticking a piece of tape on the IR sensor, I mean... ;) )?
Thanks!
ccristal
ccristal
Re: TBS 5980 freezes with Volume Down from my audio remote
Postby steven » Sat May 25, 2013 11:11 pm
Hi ccristal
Next Monday i will send you a test driver which disable the IR ,so you can
have a try. : )
Postby ccristal » Sat May 25, 2013 11:52 pm
This is great news, Steven! Thank you so much...
For now I'm adopting the "insulating tape" strategy... ;-)
ccristal
ccristal
Postby steven » Mon May 27, 2013 4:34 pm
Hi ccristal
please uninstall the TBS5980VHID first then install this driver which disabled the IR:
https://hotfile.com/dl/224677278/f73e4a ... 7.zip.html
Any problem just send reply here.
Postby ccristal » Wed May 29, 2013 1:38 am
Hi, Steven!
Thanks for the driver. I have followed your instructions and installed it, and the problem I had with my audio remote seems to have gone.
So, I'll keep version 1.0.2.8 of the driver.
Allow me to say, I'm really impressed with the level of support you offered in this occasion. Thank you once again! :)
ccristal
ccristal
Postby steven » Wed May 29, 2013 2:58 pm
Hi ccristal
Thanks for your update. :)
Postby ccristal » Tue Jul 18, 2017 10:46 pm
All of a sudden this problem started reoccurring to my setup. I have driver v1.0.3.3 installed.
Any chance you can build me a driver with the support for the IR remote disabled, as you did for v1.0.2.8?
Thank you! :-)
ccristal
ccristal
