Broken I2C-access support in latest drivers
Postby crazycat » Tue Jan 17, 2012 8:50 am
Look like I2C-access support broken in latest 1.0.2.3, 1.0.2.5 drivers for TBS5980.
So CrazyScan, BLScan and etc not work.
P.S. TBS6925,5925 still work :)
Re: Broken I2C-access support in latest drivers
Postby Ratchet1966 » Wed Jan 18, 2012 11:39 pm
crazycat Wrote:Look like I2C-access support broken in latest 1.0.2.3, 1.0.2.5 drivers for TBS5980.
I can confirm this is the case. I updated to the latest driver and lost Crazyscan support. I have since reverted to the supported driver. It would be good if new driver releases maintained the I2C access as crazycat's software is very good.
Ratchet1966
Postby crazycat » Wed Jan 25, 2012 3:02 am
And will be great, if all QBox'es drivers will be updated with I2C-access interface like 5980/5925 :)
Postby sotos65 » Tue Apr 17, 2012 7:09 pm
Does CrazyScan, BLScan, etc, work with the latest driver 1.0.2.6, or I2C access is still broken? A friend of mine wants to buy the TBS5980, and I would like to know which is the best version of drivers to work with.
sotos65
Postby steven » Wed May 02, 2012 11:09 am
Hi All
All is ok now,Please just use the latest version. :)
Postby EnoSat » Sat Sep 22, 2012 9:25 pm
actual status on my PC-Win7 32b with CrazyScan:
19:24:38 StreamReaderEx BDA Ver:1.1.0.1036-commited (Sep 16 2012, 18:54:28)
19:24:38 Log level = 1
19:24:38 DLL_PROCESS_ATTACH hModule = 63870000
19:24:38 CheckForDVBEx(0x012A7B20)
19:24:38 PID filtering disabled !
19:24:38 Power-off LNB on exit: ENABLED
19:24:38 SendDiSEqC use 2 repeats
19:24:38 Default modulation: AUTO
19:24:38 Default spectral inversion: AUTO
19:24:38 Default pilot: AUTO
19:24:38 Default rolloff: AUTO
19:24:38 Preffered BDA device type: Win7
19:24:38 Available BDA-devices:
19:24:39 Device 0
19:24:39 Name: TBS 5980 CI Tuner
19:24:39 Type: DVB-S/S2
19:24:39 StartDVBEx(0)
19:24:39 Device_ID: 0
19:24:39 Use Device 0
19:24:39 Tuner filter: TBS 5980 CI Tuner
19:24:39 Capture filter: TBS 5980 CI Capture
19:24:39 Microsoft Windows7 BDA extension used !
-and show info aout unsuport
actual status with Blscan in Win7 32b:
19:48:36 StreamReaderEx BDA Ver:1.1.0.1036-commited (Sep 16 2012, 18:54:28)
19:48:36 Log level = 1
19:48:36 DLL_PROCESS_ATTACH hModule = 67000000
19:48:36 CheckForDVBEx(0x010D1000)
19:48:36 PID filtering disabled !
19:48:36 Power-off LNB on exit: ENABLED
19:48:36 SendDiSEqC use 2 repeats
19:48:36 Default modulation: AUTO
19:48:36 Default spectral inversion: AUTO
19:48:36 Default pilot: AUTO
19:48:36 Default rolloff: AUTO
19:48:36 Preffered BDA device type: AUTO
19:48:36 Available BDA-devices:
19:48:36 Device 0
19:48:36 Name: TBS 5980 CI Tuner
19:48:36 Type: DVB-S/S2
19:48:36 StartDVBEx(0)
19:48:36 Device_ID: 0
19:48:36 Use Device 0
19:48:37 Tuner filter: TBS 5980 CI Tuner
19:48:37 Capture filter: TBS 5980 CI Capture
19:48:37 Tuner IC: STB6100
19:48:37 Frontend/demod IC: STV090X (cut 3.0)
19:48:37 TBS STB6100/STV090X direct control used !
19:48:37 BBGain = 8 dB
19:48:37 Turbosight (QBOX - Cypress FX2 based) BDA extension used !
19:48:37 + Turbosight BlindScan support with STV090X
19:48:37 + Turbosight IR control support
19:48:37 + Turbosight CI support
19:48:37 + Turbosight I2C access support
19:48:37 + Turbosight fast LNB control support
-and start scan
maybe some idee for help with CrazyScan ?
regards
EnoSat
