Not always working
Not always working
Postby satking » Thu Jan 05, 2012 12:52 am
If I disconnect the tuner and reconnect when required in windows 7 media center it will not work unless the system is rebooted ,it works fine with dvb viewer, drivers are up to date.
satking
Re: Not always working
Postby steven » Mon Jan 09, 2012 11:41 am
Hi satking
When you disconnect the tuner and reconnect, do you have restart Windows Meida Center?
Maybe this is a bug of Windows Meida Center.
Postby satking » Mon Jan 23, 2012 7:06 am
No I have to restart the system,restarting media center will not work.
When I set a recording on media center and the system goes into standby when it resumes for the recording
it will not record saying that there is no signal.
I have dvb viewer that works good all the time.
satking
