TBS5921 can't compile raspbian
Postby tuksmr » Sun Aug 24, 2014 8:27 pm
i'm trying to compile drivers on raspbian, but there is error.
root@raspberrypi /usr/src/tbs-linux-drivers/linux-tbs-drivers # uname -a
Linux raspberrypi 3.10-3-rpi #1 Debian 3.10.11-1+rpi7 (2014-05-05) armv6l GNU/Linux
root@raspberrypi /usr/src/tbs-linux-drivers/linux-tbs-drivers # gcc -v
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/arm-linux-gnueabihf/4.6/lto-wrapper
Target: arm-linux-gnueabihf
Configured with: ../src/configure -v --with-pkgversion='Debian 4.6.3-14+rpi1' --with-bugurl=file:///usr/share/doc/gcc-4.6/README.Bugs --enable-languages=c,c++,fortran,objc,obj-c++ --prefix=/usr --program-suffix=-4.6 --enable-shared --enable-linker-build-id --with-system-zlib --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --with-gxx-include-dir=/usr/include/c++/4.6 --libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --enable-gnu-unique-object --enable-plugin --enable-objc-gc --disable-sjlj-exceptions --with-arch=armv6 --with-fpu=vfp --with-float=hard --enable-checking=release --build=arm-linux-gnueabihf --host=arm-linux-gnueabihf --target=arm-linux-gnueabihf
Thread model: posix
gcc version 4.6.3 (Debian 4.6.3-14+rpi1)
i tried ./v4l/tbs-x86.sh and /v4l/tbs-x86_r3.sh but still the same error and i cant run my card :/
 CC [M]  /usr/src/tbs-linux-drivers/linux-tbs-drivers/v4l/dvb_dummy_fe.o
  CC [M]  /usr/src/tbs-linux-drivers/linux-tbs-drivers/v4l/af9013.o
  CC [M]  /usr/src/tbs-linux-drivers/linux-tbs-drivers/v4l/cx24116.o
  CC [M]  /usr/src/tbs-linux-drivers/linux-tbs-drivers/v4l/tbsfe.o
  LD [M]  /usr/src/tbs-linux-drivers/linux-tbs-drivers/v4l/tbs6980fe.o
ld: /usr/src/tbs-linux-drivers/linux-tbs-drivers/v4l/tbs6980fe_driver.o: Relocations in generic ELF (EM: 3)
/usr/src/tbs-linux-drivers/linux-tbs-drivers/v4l/tbs6980fe_driver.o: could not read symbols: File in wrong format
make[5]: *** [/usr/src/tbs-linux-drivers/linux-tbs-drivers/v4l/tbs6980fe.o] Błąd 1
make[4]: *** [_module_/usr/src/tbs-linux-drivers/linux-tbs-drivers/v4l] Błąd 2
make[3]: *** [sub-make] Error 2
make[2]: *** [all] Error 2
make[2]: Leaving directory `/usr/src/linux-headers-3.10-3-rpi'
make[1]: *** [default] Błąd 2
make[1]: Opuszczenie katalogu `/usr/src/tbs-linux-drivers/linux-tbs-drivers/v4l'
make: *** [all] Błąd 2
could anybody help me?
tuksmr
Re: TBS5921 can't compile raspbian
Postby crazycat » Mon Aug 25, 2014 4:32 am
precompiled frontend driver only for x86, x86_64 :)
Postby tuksmr » Mon Aug 25, 2014 3:54 pm
crazycat Wrote:precompiled frontend driver only for x86, x86_64 :)
that's right, i'm using different architecture :/
tuksmr
