TBS BlindScan 3.0.0.4
Postby paulus » Fri Jun 17, 2011 1:21 am
Probably no suprise to anyone here, but the latest BlindScan v3.0.0.4 does not work.
At least with other versions of this defective software I could make changes with the physical setup, obtain some results, and determine where the issues were.
In this version there were no results on any of the different physical setups. I used a switch, bypassed the switch, tried my Cband setup, and tried my KU setup with several different standard and universal lnbs.
Removing the latest version and putting the older one back on at least allows me to obtain some results, as long as there is no disecq and no need for 22khz. That is of course if you consider 3 Transponders being found from the the 17 I can scan in using one of my multiple STBs and hauppauge card, "results".
Another fantastic release from TBS. I am finding it hard to justify spending 3-4 hours screwing around with this thing every time a half assed release is put out.
paulus
Re: TBS BlindScan 3.0.0.4
Postby steven » Fri Jun 24, 2011 2:55 pm
Hi do you use the latest driver of TBS5921?
