Shadow in recived video !!!
Postby zaghlol » Fri Feb 10, 2012 6:53 am
HI,
I Have dual channel card TBS6980 running on ubuntu 11.10, i do update ubuntu . i always have a problem with sports channel , the video comes with shadow . i also try the card with windows 7, i got the same problem !! please see the video pic in attachment .
is it from the video codec ? and how to change the video codec in unbuntu ?
please advice ,
zaghlol
Re: Shadow in recived video !!!
Postby SergioDanielG » Fri Feb 10, 2012 7:56 am
If you have the same problem in ubuntu and w7, the proble isn't the codec. See the top-left corner of image. There aren't shadow.
Maybe low resolution in original video.
Best regards.
SergioDanielG
Postby zaghlol » Sat Feb 11, 2012 12:01 am
Well if the video is slow the quality of picture is perfect! But if it is little fast you can notice the shadow .
that;s why the logo quality is very good !!
zaghlol
