That is not wonder, since your driver supports kernel up to 2.6.34 version only.
So, my question is simple - when ?
sami8519 Wrote:Edit: they are inside the v4l directory.
sami8519 Wrote:I tested the remote control in VDR and only the zapping between channels and numbers are working. No control of sound up/down,mute,menu, or colured buttons,...etc
Is there settings I have to do or this is all what is working at the moment?
cody Wrote:sami8519 Wrote:I tested the remote control in VDR and only the zapping between channels and numbers are working. No control of sound up/down,mute,menu, or colured buttons,...etc
please, check posts of "blckcat" here:
viewtopic.php?f=22&t=103&start=10#p613
viewtopic.php?f=22&t=103&start=10#p615
it's fully working with using the proper settings.
sami8519 Wrote:maybe you can correct the error that Michael discovered that make the remote control fully working and reupload the driver please?
cody Wrote:sami8519 Wrote:maybe you can correct the error that Michael discovered that make the remote control fully working and reupload the driver please?
of course, i will do that when i have a chance to look more at it.
