Problem with TBS 8921 in TSReader console
Postby enb141 » Mon Mar 26, 2012 9:23 am
Hi I'm trying to configure TSreader to work in console mode but when I choose to specify the frequency, etc it simply shows a window with an error.
this is the command line I've used
TSReader.exe -H+8 f:\temp\test.htm 11050 V 27902 11700 0 3 (I'm using DiSEq port 3)
enb141
Re: Problem with TBS 8921 in TSReader console
Postby steven » Wed Mar 28, 2012 11:26 am
Hi enb141
Thanks for your feedback.
TBS8921 can not use console module in TSReader now.
Need to update the TSReader's DLL.
Would you mind using the Normal module first. :)
Postby enb141 » Thu Mar 29, 2012 9:17 am
I'm currently doing it in that way, but I is slower and I was looking for an automated way to run it so I hope you could provide us with a new TSReader dll that could work in console mode.
By the way the Normal module works fine with TBS 8921.
enb141
