About BSOD
About BSOD
Postby steven » Fri Jun 24, 2011 3:01 pm
Hi all
Here is the TBS8921 win7 64bit driver which have not IR,because we think it maybe the IR cause the BSOD.
So all would you mind try this to have a test.and send your test report.
here is the driver:
http://hotfile.com/dl/121851650/fafab48 ... r.rar.html
Re: About BSOD
Postby AndersM » Mon Jun 27, 2011 1:03 am
Hi Steven!
Do You have TBS8921 win7 32bit driver which have not IR,because i am getting BSOD´s on Win 7 32bi aswell......
Best Regards
/Anders
AndersM
Re: About BSOD
Postby steven » Mon Jun 27, 2011 10:34 am
AndersM Wrote:Hi Steven!
Best Regards
/Anders
Would mind which player you are use when got BSOD, MCE, TBSView and so on ..?
and later i will give you a 32bit version.
Re: About BSOD
Postby steven » Mon Jun 27, 2011 10:54 am
Would mind try this version which have not BlindScan.
http://hotfile.com/dl/122329714/a682382 ... S.rar.html
Waiting for your test report.
Re: About BSOD
Postby nikos1671 » Mon Jun 27, 2011 9:45 pm
What about 32bit win7?????
nikos1671
Re: About BSOD
Postby riccume » Sat Jul 16, 2011 7:05 am
Hi Steven, I've also been experiencing several BSODs with Win 7 32bit while using W7MC + TV Source. I took a look at the reports and in all of them the Bug Check String is "BAD_POOL_CALLER" and among the drivers found in the stack I always see tbs8921.sys (the others being halmacpi.dll, ks.sys, ntkrnkpa.exe, by Microsoft). Will you be able to provide an updated driver? Thanks.
riccume
Re: About BSOD
Postby steven » Tue Jul 19, 2011 3:10 pm
riccume Wrote:Hi Steven, I've also been experiencing several BSODs with Win 7 32bit while using W7MC + TV Source. I took a look at the reports and in all of them the Bug Check String is "BAD_POOL_CALLER" and among the drivers found in the stack I always see tbs8921.sys (the others being halmacpi.dll, ks.sys, ntkrnkpa.exe, by Microsoft). Will you be able to provide an updated driver? Thanks.
hi do you have used the latest driver on downloader page:
http://www.tbsdtv.com/download/8921/TBS ... .0.0.7.rar
thanks
Re: About BSOD
Postby Derrick » Wed Jul 20, 2011 3:50 am
steven Wrote:hi do you have used the latest driver on downloader page:
thanks
That's exactly what I did. I also installed the new blind scan tool 3.0.0.5. No BSOD anymore but things turned from bad to worse.
The performance with low SR transponders is much worse than before (I still use the debug driver 8921dbg). Many active transponders are missing. According to the specs the card should be able to handle symbols rates >1MS/s. But this is not true. A different card shows no problems:
Derrick
Re: About BSOD
Postby Derrick » Wed Jul 20, 2011 4:00 am
About blind scan... Though no BSOD occurred the yield of all scans is nada! Besides after changing diseqc the card went to sleep. Only after deactivating/activating the card in the device manager the TBS8921 went back to work.
What a progress since I posted about poor performance in January of this year :lol:
Derrick
Re: About BSOD
Postby steven » Fri Jul 22, 2011 11:34 am
Derrick Wrote:About blind scan... Though no BSOD occurred the yield of all scans is nada! Besides after changing diseqc the card went to sleep. Only after deactivating/activating the card in the device manager the TBS8921 went back to work.
This driver can solve the diseqc problem,
http://hotfile.com/dl/124703782/73664c1 ... e.rar.html
thanks
