[ Moderator Control Panel ]
by joolzg » Tue Mar 24, 2015 5:44 am
We have tried everything and can only get 1 card to work in a pc at a time
Anyone had this and solved this?
joolz
joolzg
by smile » Wed Mar 25, 2015 10:52 am
Hi Joolzg,
i think you should be misunderstanding. TBS6925 only one tuner.the other tone is the loop out.you can see the mark on the board.
Best Wishes
smile
by joolzg » Wed Mar 25, 2015 3:11 pm
No I think you misunderstand.
1 PCI card 1 input
2 PCI card NOT WORKING
We cannot put more than 1 6925 card in a PC at a time.
joolzg
by SergioDanielG » Mon May 04, 2015 6:29 am
I'm not sure why you can't, but I'm using three pci-e cards in same pc. A tbs6935 (tuner 3), a tbs6920 (tuner 2) and a tbs6982 (tun ers 0 and 1).
What lspci say about your cards?
SergioDanielG
by joolzg » Mon May 04, 2015 1:38 pm
Sergio, the problem is the NEW 6925 card, we have machines with over 4 cards and no problems.
joolzg
by crazycat » Tue May 05, 2015 3:25 am
two 6925 under linux ?
