27.5 west channels
27.5 west channels
Postby dogman » Tue Dec 23, 2014 3:29 am
Has anyone managed to get the UK Freeview channels on 27.5 west working on their 6925?
If yes, how?
dog-man...
dogman
Re: 27.5 west channels
Postby smile » Thu Jan 29, 2015 5:02 pm
you see http://www.lyngsat.com/Intelsat-907.html.all of the freeview channel are in the C-band frequency.are your using the C-band dish? are you setting right all of the search param?
Best Wishes
smile
Postby dogman » Thu Jan 29, 2015 9:08 pm
No they are not.
dogman
Postby DVB » Fri Jan 30, 2015 4:21 am
If You got signal - add channels manually (as PMT table in DVB stream is encrypted with OTHER B*SS key than channels), find key online (not always public, but now it is) & watch.
PS: Some channels (HD and radio stations) got AAC audio.
And now you're watching 8K:
KKKKKKKK
DVB
Postby dogman » Fri Jan 30, 2015 4:26 am
I can find keys easily myself.
dogman
Postby DVB » Fri Jan 30, 2015 4:33 am
So what is the problem? Enter key and watch. PMT is encrypted with other key so cannot scan channels, add them manually.
EDIT: Not PAT - PMT is encrypted, my mistake. Without PMT - no PID's.
KKKKKKKK
DVB
