Two Tbs pci-e cards 6925+6982 in a system WIN7 x64
Postby michalmichal » Sat Feb 01, 2014 5:49 am
Do two Tbs pci-e cards 6925 and 6982 (both pci-e based on SAA7160) work together properly in a system WIN7 x64 ? I have TBS6982 and I want to buy TBS6925 but I am not sure if the combination of 6925 and 6982 in the same computer work well.
Once I read that there is conflict : quote: 'Direct hardware control for TBS/Prof PCI, PCI-E limited to first device instance (all SAA716x, SAA713x based devices also)' then I read that somebody uses TBS 6982 and TBS6280 together (both based on SAA7160 ) properly in one WIN7 x64 system
http://www.sevenforums.com/media-center ... -side.html
Can you confirm that combination of two different pci-e TBS cards both based on SAA7160 should work properly together in one Win7 x64 system ?
If somebody uses two pci-e TBS cards both based on SAA7160 together in WIN7 x64, write how it workes together!
michalmichal
Re: Two Tbs pci-e cards 6925+6982 in a system WIN7 x64
Postby SergioDanielG » Tue Feb 04, 2014 8:45 pm
Hi michalmichal.
I usually use linux, but in few opportunities I used TBS6925, TBS6982 and TBS6920 in Windows7 without problems.
Hope it's util for you.
Regards.
SergioDanielG
