Old OEM TBS Versions of ProgDVB
Postby ScanMan » Tue Jan 28, 2014 3:06 am
Have you any links to old TBS OEM versions of ProgDVB, the version on the downloads page is version 6.96.2?
If older versions are available would you please be able to provide some links? The versions I prefer are the last versions using ProgDVB Engine 4.x. that support hardmode and some other older functions. I think these are version up to 6.61.1 but not after this version?
ScanMan
Re: Old OEM TBS Versions of ProgDVB
Postby crazycat » Tue Jan 28, 2014 3:40 am
First ProgDVB TBS OEM is 6.93.2 - engine 6.5. Same as ProgDVB Standard Edition.
Postby ScanMan » Tue Jan 28, 2014 9:29 pm
crazycat Wrote:First ProgDVB TBS OEM is 6.93.2 - engine 6.5. Same as ProgDVB Standard Edition.
Not correct, I have TBS card and CD that come with card has OEM ProgDVB versin 6.5, what you say to that ?
ScanMan
Postby crazycat » Wed Jan 29, 2014 4:13 am
maybe very old.
