Advice needed please from support
Postby dogman » Sat Jan 11, 2014 2:45 am
My 6925 card which is a replacement for a card that lost the ability to find S2 transmissions, today whilst scanning a satellite using DVB Dream suddenly froze and I had an error and my computer crashed.
It was some sort of exception for tbs6925_64.sys.
Since then, no matter what I do, no DVB program can find the card.
I have tried uninstalling the card and all drivers.
I also uninstalled the drivers manually to make sure that they were all deleted in case one of them was corrupt.
I re-installed the drivers and the card is showing in device manager with no problems, but still no DVB program can find the card.
So, what could be the problem?
I only had this replacement just a few days before Christmas. It has been operating fine since then until today.
dog-man...
dogman
Re: Advice needed please from support
Postby steven » Sat Jan 11, 2014 8:08 pm
Hi dogman
Do you have tried to restart your PC?
is it can rework again?
Postby dogman » Sat Jan 11, 2014 10:33 pm
Yes, I have restarted my PC several times. The card is showing in 'device manager' but no DVB program can see the card.
I shall remove the card later today and reinstall and see if that does anything.
dog-man...
dogman
Postby ScanMan » Sun Jan 12, 2014 6:21 pm
Are you able to try installing the card in another computer? If the card is not working after a clean install in another computer that would probably indicate a fault with the card rather than the software?
ScanMan
Postby dogman » Sun Jan 12, 2014 9:22 pm
I never thought of that!
Very silly of me as I do have another two computers I could try that in.
Anyway, at the moment it is working again. I took the card out of my computer and then re-inserted it and so far, it is working.
Only did it a few minutes ago, so I will see how long it lasts.
I hope it now continues to work forever as I love what this card can do.
dog-man...
dogman
