New TSReader 1.0.8.2 Source
Postby starman345 » Sat Jun 16, 2012 5:12 am
HI Steven,
I installed the new TBS sources today and notice that with both the 6925 and 8922 I no longer have a signal or quality reading. Where those used to be I now have Signal: Unlocked
Everything seems to run normally other than that.
10' dish- Bullseye II c/ku
55.5W to 139W
Windows 8.1 64 bit
TBS 8922 Prof 7301 TBS 6925
starman345
Re: New TSReader 1.0.8.2 Source
Postby steven » Mon Jun 18, 2012 11:30 am
Hi starman345
Would you mind having a test with this new version:
https://hotfile.com/dl/160248716/245e829/tsreader-bdasource_v1.0.8.3.zip.html
This should be ok. :)
Please send your test report here.
Postby starman345 » Mon Jun 18, 2012 8:16 pm
Thank you Steven for the fast reply. The new source now returns values in both the 6925 & 8922 however those signal/quality values seem to be reversed ie: signal value in 6925 = quality value in 8922. See pictures
55.5W to 139W
Windows 8.1 64 bit
starman345
Postby steven » Tue Jun 19, 2012 12:00 pm
Hi starman345
Thanks for your reply. :D
every card's sensitivity is different ,so the value maybe have a little difference . :)
Postby starman345 » Tue Jun 19, 2012 7:44 pm
I understand each card will show different values and overall they don't mean much anyway but I find it interesting that the 6925 and 8922 cards show opposite values on every signal I try. :)
55.5W to 139W
Windows 8.1 64 bit
starman345
