tbs ip tool
tbs ip tool
Postby Zbabbir » Thu Jul 21, 2011 12:04 am
I'm using windows 7 64bit with the 64bit drivers.
I can lock on channels but when I want to use the ip tool, it appears to do nothing. First of all, it's not showing the active pids on the first time. I need to either set the mac address for several times until they show or close and reopen the ip tool.
When I chose the pid and mac address the ip tool program doesn't show me the channel rate (it stays on 0), so basically it just shows me the active pids and then does nothing. I tried to use wireshark and sniff the virtual network interface that the tbs driver creates but it shows no traffic.
Help?
Zbabbir
Re: tbs ip tool
Postby steven » Thu Jul 21, 2011 9:08 am
When you want get rate,would you mind uncheck the show all active pid,this is a small bug,later version i will fix it.
Re: tbs ip tool
Postby baber » Tue Aug 23, 2011 9:57 pm
Hi. i have many problem with tbs ip data i installed all of version
1-tbs ip data not work correctly with Usals it can move only between 4E-62E from 62e - 105e it can not move and any of west position can not fix why?
2-when i select my location and select sattelite for set and select go bot of signal strength and quality cutted and not show
3- when i open tbs ip data and have no signal after 5-10 second blue screen appear
i am very confused my windows is 7 and i change and reinstall that but not solve my problem i asked most of them have 6925 have these problems
please help me
baber
Re: tbs ip tool
Postby steven » Thu Aug 25, 2011 2:26 pm
Hi baber
would you mind try this new driver
it is for win7 32bit and 64bit version,
http://hotfile.com/dl/127851485/6206136/TBS6925Win764.rar.html
http://hotfile.com/dl/127851496/f3ac017/TBS6925Win7-32.rar.html
wait for your test report.
Re: tbs ip tool
Postby baber » Fri Aug 26, 2011 6:10 pm
only in this driver untill now blue screen error not appear but problem with usales not solved
problem with strenght signal not solved (strenght signal is very weak my dish is in best position in tbs 8920 have not this problem)
problem with blindcan not solved blind scan take a long time(30-40min for each sattelite take time) for search new freq
baber
Re: tbs ip tool
Postby tales21 » Sat Aug 27, 2011 3:08 am
hi
Mac-speed satellite Internet can not be completed on tbs-ip_data
please help!
tales21
