How to watch free MTV HD and MTV Music HD channels with 6925
Postby steven » Mon Jul 11, 2011 4:03 pm
hi,guys
Here i share some useful info of watching free MTV/MTV Music HD channels with our TBS6925,see as follows:
There are MTV HD and MTV Music HD channels broadcasted on Atlantic Bird 1 satellite 12.5W. This transponder is broadcasted with Multi Input Stream (MIS) mode which means a standard satellite receiver or satellite TV tuner which normally doesn’t have Multi Input Stream feature can’t receive these programs. But with TBS6925 which is a professional level DVB-S2 TV Tuner card you can receive MTV HD and MTV Music HD easily if only you’re under the footprint of Atlantic Bird 1. It seems to be covering the whole Europe including Iceland, North Africa, Middle East, Western part of Russia, Eastern part of North America including part of Canada, Cuba, Dominica, part of Mexico and the whole South America. Check this link http://www.eutelsat.com/satellites/125e_popd.html# in some weak signal region you may need a big dish. But the following report was done on site in Europe by cody, so there is no guarantee that you can receive the same transponder elsewhere.
Before you may start your scan, download the latest driver and TBSrecorder from TBS download zone:http://www.tbsdtv.com/english/Download.html
This report is tested with combination of TBS6925Driver_V1.0.1.4 and TBSRecorder(V3.0.0.3).
The details of this transponder are:
Atlantic Bird 1 satellite at 12.5 West
12718 H, 36510, FEC 5/6,
8PSK Multiple Input Stream (MIS) transponder with four TS
Stream IDs: 33, 34, 35 36
Here are the screenshots and guide about how to filter MIS stream and watch/record it with DVB player.
1) Use TBSRecorder to lock the MIS frequency and after that choose "Input Stream ID" from the drop-down box and press "Apply" button – in the example MIS ID of 34 is selected:
2) Close TBSRecorder. It's not necessary to run it anymore after the MIS filter is set, i.e. the "Input Stream ID" is selected and applied.
3) (Optional) check with TransEdit that the correct TS stream is filtered (this step is not really necessary).
After check, you need to close TransEdit.
4) Open your favorite DVB player software (in the example TBSViewer is used, but of course you may use other software like DVBViewer, DVBDream, ProgDVB…) and then scan the same transponder from 1).
scan is finished and four channels are found:
the list of found channels including MTV MUSIC HD and MTV HD.
5) select MTV MUSIC HD or MTV HD channel from the list and watch it, currently they are not encrypted and you can watch these crystal clear HD channels free.
6) more screenshots from MTV HD and MTV MUSIC HD, which are available on the MIS transponder from the example:
7) if you want to change selected MIS ID you need to repeat the step 1) and also if you don't have the channels from that MIS ID in your channel lists, re-scan in your favorite DVB player software.
It’s very easy for you to use the record or scheduled record features of the DVB player software for PVR.
Re: How to watch free MTV HD and MTV Music HD channels with
Postby sotos65 » Mon Jul 11, 2011 8:17 pm
Great, thanks! :) 8-)
It was already possible to lock different streams with the latest version of CrazyScan, and watch the channels using the TSReader analyzer and VLC, but with this new tip it is way much easier now! Btw, the two MTV channels are not transmitting (so far) native HD programs, they just upscale SD content.
sotos65
Postby steven » Thu Jul 14, 2011 2:24 pm
hi,guys.
Mr.Orbita from SatKurier Poland just discovered MTV Music HD was replaced by La 7 3D on July,13,here's the screenshot. For more details,please visit
http://satkurier.pl/news/66869/wloskie-mtv-fta-w-hd-z-12-5w.html
it could be a good news that you can enjoy 3D TV from that transponder.
Postby DVB » Fri Jul 15, 2011 4:48 am
Ooops :P Small misunderstanding :P MTV Music HD was replaced by La7d HD (La7d is italian channel for ladies). Channel is present in MIS 34 (with MTV HD).
La7 3D test mentioned in satkurier.pl news is present in mux for much longer, probably few months in MIS 36 ;)
Also new in MIS 33 - Canal One
Actual lineup of Atlantic Bird 1 package (scanned just few minutes ago, PID V/A/PCR/SID, all channels are Free To Air!):
Atlantic Bird 1 (12,5°W)
tp. F7 (12,718 GHz, pol. H, SR: 36512, FEC: 5/6; DVB-S2/8PSK)
MIS33:
- CanalOne (981/982/981/16)
- MEDIASET EXTRA (1750/1751/1750/19)
- HSE24 (780/781/780/22)
- Real Time (2462/2463/2462/44)
- QVC (6092/6093/6092/80)
- QVC Replica (6095/6096/6095/90)
- LA5 (760/761/760/160)
MIS34:
- RTL 102.5 TV (790/791/790/21)
- MTV HD (766/768/766/611)
- LA7D HD (770/772/770/617)
- LA7 HD (757/758/757/700)
MIS35:
- MTV MUSIC (6132/6133/6132/120)
- MTV MUSIC (6132/6133/6132/121)
- LA7 (6112/6113/6112/140)
- frisbee (1457/1458/1457/146)
- MTV (6117/6118/6117/150)
- K2 (981/982/981/151)
- LA7 (6112/6113/6112/613)
- MTV (6117/6118/6117/614)
- LA7D (6122/6123/6122/617)
- LA7D (6122/6123/6122/618)
- La7ondemand (2039/0/2039/623)
MIS36:
- LA7 test 3D (762/763/762/701)
- LA7 test MOSAICO (101/0/101/703)
European users should be also interested in other ACM/VCM package from 31,5°E with Sport Italia channels. Actual lineup (only MIS 2 is in use)
Astra 1G (31,5°E)
tp. 11 (11,914 GHz, pol. H, SR: 27500, FEC: ?/?; DVB-S2/8PSK)
MIS2:
- SPORTITALIA (258/259/258/1)
- SPORTITALIA2 (514/515/514/2)
- SPORTITALIA24 (770/771/770/3)
- Tivuitalia test 4 (1026/0/1026/4)
- Tivuitalia test 5 (1026/0/1026/5)
- Tivuitalia test 6 (1026/0/1026/6)
- Tivuitalia test 7 (1026/0/1026/7)
- Tivuitalia test 9 (1026/0/1026/13)
Tivuitalia test 4-9 = Teleitalia testcard.
And now you're watching 8K:
KKKKKKKK
DVB
Postby steven » Fri Jul 15, 2011 2:30 pm
hi DVB,
Thank you for correct our misunderstanding.Do not hesitate to add your Image again,it cannot be displayed. :|
Postby DVB » Sat Jul 16, 2011 11:00 am
Sorry for that, I forgot that there is possibility to upload images directly ;) Now it should be ok :)
sport italia.jpg (28.21 KiB) Viewed 16258 times
KKKKKKKK
DVB
