How use tbs ip data
How use tbs ip data
Postby baber » Thu Jul 07, 2011 7:41 pm
Hi . i bought tbs6925 but in tbs ip data where can i select my frequency is 16,32APSK or 8 psk? in tbs ip data 6925 dvbcard i can not see any option for this mood
please help me.
baber
Re: How use tbs ip data
Postby steven » Fri Jul 08, 2011 10:23 am
you need to use TBS 6925 Recorder.
Postby baber » Fri Jul 08, 2011 3:53 pm
i install TBS6925-TSRecorder but in TBS6925-TSRecorder there is not any fileld for select 16aps or 32 aps where do i have to select my Modulation type ?
baber
Postby baber » Fri Jul 08, 2011 9:56 pm
i want recieve 16aps or 32aps data frequency with tb6925 i only bought this dvbcard for this work
how can recieve these frequency in tbs ip data for internet via satelite on these frequency?
baber
Postby steven » Sat Jul 09, 2011 9:26 am
baber Wrote:i install TBS6925-TSRecorder but in TBS6925-TSRecorder there is not any fileld for select 16aps or 32 aps where do i have to select my Modulation type ?
Hi Baber
In TBS6925-TSRecorder you do not need to input 16aps or 32 aps, you can try to lock one transponder if this transponder is a 16aps or 32 aps ,TBS6925-TSRecorder will show the apsk,so you do not need to select Modulation type,tbs6925's driver will auto detect the Modulation type.
Postby baber » Sat Jul 09, 2011 2:03 pm
excuseme if i want recieve 16aps or 32 aps data frequency in tps ip data first i have to put the frequency in tbs recorder then put in tbs ip data? or only put it in tbs ip data for exaple many 16aps or 32 aps data frequency on eutelsat w6 can recieve that?
baber
Postby dubaisatshop » Sun Jul 10, 2011 12:25 am
baber Wrote: many 16aps or 32 aps data frequency on eutelsat w6 can recieve that?
It depends on your location
dubaisatshop
Postby baber » Sun Jul 10, 2011 12:35 am
not problem from location sattelite coverage my location my means only was can recieve 16aps or 32 aps data frequency with tbs ip data or need other softwares?
baber
