TBS Blind Scan Utility 3.0.0.8 no 22khz switching?
Postby starman345 » Fri Feb 10, 2012 6:30 am
I noticed version 3.0.0.8 no longer has the 22khz on/off switch box found on earlier versions. I switch between c and ku bands on my system via 22khz on/off. Can this option be added?
10' dish- Bullseye II c/ku
55.5W to 139W
Windows 8.1 64 bit
TBS 8922 Prof 7301 TBS 6925
starman345
Re: TBS Blind Scan Utility 3.0.0.8 no 22khz switching?
Postby steven » Fri Feb 10, 2012 9:35 am
starman345 Wrote:Hi,
Hi starman345
22khz on/off just use High band or low band instead.High band means 22khz on,low band means 22khz off.
And about the c and ku bands 22khz set ,this problem will be fixed next version.
Next version will add scan for all option,22k on or off, H or V all scan once.
Sorry for this problem,just wait our new version of Blindscan tool. :)
Postby steven » Tue Feb 14, 2012 3:40 pm
Hi starman345
After fews days work,TBS Blindscan tool can scan low/high. H/V together.
and can set 22k in Ku band or C band.
Here is the new TBS Blindscan tool, would you mind tring this new version to have a test .
and send your test report.
Here is the file:
http://hotfile.com/dl/146480916/f81fba5/Setup_TBS_BlindScan(3.0.0.9).zip.html
Thanks very much.
Best regards
Postby starman345 » Wed Feb 15, 2012 2:13 am
3.0.0.9 works fine with both 6925 and 8922 cards, thanks Steven, see PM for more detailed report
55.5W to 139W
Windows 8.1 64 bit
starman345
