Defective/Hardware Problems with TBS 6925 8PSK freq only.
Postby Tomek22 » Tue Dec 19, 2017 11:45 pm
Hello
My tbs 6925 stopped working correctly. There are problem to lock any 8PSK frequency. It shows big BER and errors and dB only, without lock. Sometimes card it's not detected by motherboard. Tested on three PC's.
My version of TBS 6925 is V30
I also have a prof 7301 which works correctly with same installation.
To show it better i uploaded a video for you. Only DVB-S QPSK frequencies work correctly
https://www.youtube.com/watch?v=yYEgj_Vm72A
Any chances to repair that or get new card?
Tomek22
Re: Defective/Hardware Problems with TBS 6925 8PSK freq only
Postby Tomek22 » Sat Dec 23, 2017 5:08 pm
any help?
Tomek22
Postby steven » Mon Dec 25, 2017 10:51 am
Hi Tomek22
Sorry that for 6925 is very older it can not repair now,we have not the tuner and demo in stock , you can have a look at our TBS6903 or TBS6908 which is the new version of TBS6925
you can check here :
https://www.tbsiptv.com/tbs6908-profess ... earch=6908
And if you do not need to lock the ACM MIS GS stream you can try our normal TBS card such as TBS6902 or TBS6904:
https://www.tbsiptv.com/tbs6904--dvb-s2 ... earch=6904
