Tuner order changing under 18.4 Ubuntu
Postby Drifting » Tue Dec 11, 2018 9:27 pm
Please bear with me on this as I am partially sighted.
I have spent hours following instructions on how to keep my tuner cards in the same order after each reboot. Both of my cards are TBS, one is a 6281SE the other 6982.
Read that I could add a dvb.conf to modprobe.d which I tried.
options tbsecp3 adapter_nr=0,1
options saa716x_tbs-dvb adapter_nr=2,3
Which did nothing? so either I have the driver names wrong? or something else?
Started to read about Udev, but there was so much confusing contrary information, that after nearly 6hrs of on and off reading when my eyes allowed, I just had to give up.
So where do I go from here? I am at a complete loss. Any help would really be appreciated.
Paul.
Drifting
Re: Tuner order changing under 18.4 Ubuntu
Postby Drifting » Fri Dec 28, 2018 12:32 am
I am getting pretty confused by Udev, cannot really understand what is needed. Can someone please help me create the right udev rules needed to fix the order that these card work in? Using Ubuntu 18.04 LTS and Myth .29 fully patched.
looking at parent device '/devices/pci0000:00/0000:00:1c.1/0000:30:00.0':
KERNELS=="0000:30:00.0"
SUBSYSTEMS=="pci"
DRIVERS=="TBSECP3 driver"
ATTRS{broken_parity_status}=="0"
ATTRS{class}=="0x048000"
ATTRS{consistent_dma_mask_bits}=="32"
ATTRS{current_link_speed}=="2.5 GT/s"
ATTRS{current_link_width}=="1"
ATTRS{d3cold_allowed}=="1"
ATTRS{device}=="0x6178"
ATTRS{dma_mask_bits}=="32"
ATTRS{driver_override}=="(null)"
ATTRS{enable}=="1"
ATTRS{irq}=="31"
ATTRS{local_cpulist}=="0-1"
ATTRS{local_cpus}=="3"
ATTRS{max_link_speed}=="2.5 GT/s"
ATTRS{max_link_width}=="1"
ATTRS{msi_bus}=="1"
ATTRS{numa_node}=="-1"
ATTRS{revision}=="0x00"
ATTRS{subsystem_device}=="0x0002"
ATTRS{subsystem_vendor}=="0x6281"
ATTRS{vendor}=="0x544d"
looking at parent device '/devices/pci0000:00/0000:00:1c.0/0000:20:00.0':
KERNELS=="0000:20:00.0"
SUBSYSTEMS=="pci"
DRIVERS=="SAA716x Budget"
ATTRS{consistent_dma_mask_bits}=="64"
ATTRS{device}=="0x7160"
ATTRS{dma_mask_bits}=="64"
ATTRS{enable}=="1"
ATTRS{irq}=="16"
ATTRS{msi_bus}=="1"
ATTRS{revision}=="0x03"
ATTRS{subsystem_vendor}=="0x6982"
ATTRS{vendor}=="0x1131"
Regards Paul.
Drifting
Postby steven » Fri Dec 28, 2018 2:26 pm
which driver you are using ? if you are using open source driver please use this one :
vi /etc/modprobe.d/dvb.conf
options saa716x_core adapter_nr=0,1
options tbsecp3 adapter_nr=2,3
Postby Drifting » Sat Dec 29, 2018 6:51 am
Hi Steven
Thank you for the reply.
I followed your instructions, thought it had solved it till I cold booted the server, and the order changed again!
drivers I am using, tbs-open-linux-drivers_v180822.zip I believe that is the open source one?
Regards Paul.
Drifting
Postby steven » Sat Dec 29, 2018 10:30 am
Can you send before reboot the tuner order and after reboot the tuner order ? and check the configuration whether is good
or change the order to
options saa716x_core adapter_nr=2,3
Postby Drifting » Sat Dec 29, 2018 7:16 pm
Hi Steven
Thanks again for taking the time to help, really appreciated.
This morning the boot order came up the same as it did after the cold boot last night:-
[ 3.715538] TBSECP3 driver 0000:30:00.0: DVB: registering adapter 0 frontend 0 (TurboSight TBS 6281SE DVB-T/T2/C )...
[ 3.837317] SAA716x Budget 0000:20:00.0: DVB: registering adapter 2 frontend 0 (TurboSight TBS 6982SE DVB-S/S2)...
[ 3.865769] TBSECP3 driver 0000:30:00.0: DVB: registering adapter 1 frontend 0 (TurboSight TBS 6281SE DVB-T/T2/C )...
[ 4.144865] SAA716x Budget 0000:20:00.0: DVB: registering adapter 3 frontend 0 (TurboSight TBS 6982SE DVB-S/S2)...
This is what I have in dvb.conf :-
cat /etc/modprobe.d/dvb.conf
Powered it off again, pulled power, turned back on, and the same result:-
[ 3.816541] TBSECP3 driver 0000:30:00.0: DVB: registering adapter 0 frontend 0 (TurboSight TBS 6281SE DVB-T/T2/C )...
[ 3.914592] SAA716x Budget 0000:20:00.0: DVB: registering adapter 2 frontend 0 (TurboSight TBS 6982SE DVB-S/S2)...
[ 3.984506] TBSECP3 driver 0000:30:00.0: DVB: registering adapter 1 frontend 0 (TurboSight TBS 6281SE DVB-T/T2/C )...
[ 4.224809] SAA716x Budget 0000:20:00.0: DVB: registering adapter 3 frontend 0 (TurboSight TBS 6982SE DVB-S/S2)...
Regards Paul.
Drifting
Postby steven » Wed Jan 02, 2019 3:02 pm
Hi paul
Thanks for your update , from the information it is like the order works now ?
Postby Drifting » Wed Aug 07, 2019 5:27 am
This has been working great, just updated the Ubuntu and now for some reason all my cards are detected as the same? Huh?
[ 7.613301] SAA716x Budget 0000:02:00.0: DVB: registering adapter 2 frontend 0 (TurboSight TBS 6280 DVB-T/T2/C)...
[ 7.650023] SAA716x Budget 0000:02:00.0: DVB: registering adapter 3 frontend 0 (TurboSight TBS 6280 DVB-T/T2/C)...
[ 8.407940] SAA716x Budget 0000:03:00.0: DVB: registering adapter 0 frontend 0 (TurboSight TBS 6982SE DVB-S/S2)...
[ 8.736630] SAA716x Budget 0000:03:00.0: DVB: registering adapter 1 frontend 0 (TurboSight TBS 6982SE DVB-S/S2)...
Should be like this :-
What on earth is going on? Any help really appreciated.
Paul.
Drifting
Postby Drifting » Wed Aug 07, 2019 5:50 am
Oh my, so sorry I am a complete idiot. Just found out my Grandson changed the tuner, he throught he was being helpful as the last one died.
So different question, how on earth to I get the other to stay stable now? as they all use the SAA716x
Regards Paul
Drifting
