[ Moderator Control Panel ]
TBS6508 supports receiving multiple digital TV standards including DVB-S2X/S2/S/T2/T/C2/C/ISDB-T signals.
by SPiKeGoD » Fri Mar 08, 2024 8:25 am
TBS6508
In TBS6909 i have an only cable for working with the 8 adapters.
Is it possible to share an input between different input like in the tbs6909? O, do i have to connect 4 cables of the same signal?
Thanks you very much
SPiKeGoD
by smile » Fri Mar 08, 2024 2:59 pm
Hi sir
if you using dvbs/s2 mode , you need connect to 4 signal cable, one signal cable for two adapter. it is different with 6909.
if you using dvb-t or dvbc signal. you just need 1 *signal cable. connect to "RF IN" port.
Best Regards
smile
by SPiKeGoD » Fri Mar 08, 2024 4:24 pm
smile Wrote:Hi sir
Best Regards
Ok, thanks
SPiKeGoD
Return to TBS6508 Multi-standard Octa Tuner PCI-e Card
