Driver 2.0.0.9 not work
Postby fenir » Thu Jul 07, 2011 7:51 pm
Welcome
I have a problem with the driver 2.0.0.9 in my hardware configuration:
MoBo: MSI P55-GD65
CPU: Core i5 750
RAM: A-Data XPG X-Series DDR3 4GB
GPU: Msi GTX 460 1Gb
Windows 7 64 bit.
After turning DVBViewer, the program shows me just 0.2% signal strength, and the card does not work. I had to come back to driver version 2.0.0.7 and now DVBViewer shows 65% signal strength. Please fix driver 2.0.0.9. Sorry for my poor English.
fenir
Re: Driver 2.0.0.9 not work
Postby steven » Fri Jul 08, 2011 11:57 am
would mind tell us which star you are use and which transponder?
Postby fenir » Fri Jul 08, 2011 7:23 pm
steven Wrote:Hi would mind tell us which star you are use and which transponder?
Hi Steven
My tbs 6921 does not work for me on this driver 2.0.0.9, regardless of the satellite or transponder. At each transponder (Astra, Hotbird) shows me the 0.2% signal and no video or voice in the DVBViewer.
How do I change my driver to 2.0.0.7 everything back to normal. What is the reason no action on the driver 2.0.0.9?
MoBo: MSI P55-GD65
CPU: Core i5 750
HDD: 2xWD Caviar Black 500GB WD5001AALS 32MB SATA-II RAID0
PSU: Be quiet! 600W
CASE: Cooler Master ATCS 840
LCD: DELL 2408WFP S-IPS
CAR: TBS 6922 + DVBViewer 4.8.1
fenir
Postby Balamut » Sat Jul 09, 2011 2:54 pm
I have the same problem. New driver 2.0.0.9 doesn't work at all on my Win7 64-bit + DVBViewer. I can see good signal level (about 65-70%%) but no picture and sound. No relation to channel, transponder or sattelite were detected. It's also indifferent to the channel paid or free status.
Reverting back to 2.0.0.7 always fixes the problem.
i7-2600K@4500MHz, 8GB RAM, ATI HD6950@70 (900/1375MHz)
TBS 6921+SM3D12+1.2m+DKF71, Win7 64+SP1
Balamut
Postby freestat » Sat Jul 09, 2011 5:12 pm
2.0.0.8 its good.
freestat
Postby Balamut » Sat Jul 09, 2011 7:11 pm
freestat Wrote:2.0.0.8 its good.
Where can I get it? I've didn't found it on official website.
Balamut
Driver 2.0.0.9 works for XP
Postby A1880 » Sat Jul 09, 2011 10:18 pm
2.0.0.9 works for me.
But I haven't realized any improvements compared to 2.0.0.7.
A changelog would be helpful.
Greetings
A1880
My PC:
Intel Core i7-2600 @3.40GHz, 8 Cores, 8 GByte RAM, 64 Bit Windows 7 Home Premium SP1, Dell XPS 8300
A1880
Postby steven » Sun Jul 10, 2011 8:07 am
Hi Steven
Hi Fenir
sorry for the inconvenience,
Do you konw the latest BBC's change,we have modified the driver lock transponder's time,maybe this have some problem,we will give you a answer
as soon as possilbe.
Postby fenir » Sun Jul 10, 2011 8:41 am
Hi Fenir sorry for the inconvenience,Do you konw the latest BBC's change,we have modified the driver lock transponder's time,maybe this have some problem,we will give you a answer as soon as possilbe.Thanks
Thank you for your interest. I look forward to new versions of drivers that supports motherboards core i5, i7.
MoBo: MSI P55-GD65
CPU: Core i5 750
PSU: Be quiet! 600W
fenir
Postby freestat » Sun Jul 10, 2011 9:22 pm
Balamut Wrote:I have the same problem. New driver 2.0.0.9 doesn't work at all on my Win7 64-bit + DVBViewer. I can see good signal level (about 65-70%%) but no picture and sound. No relation to channel, transponder or sattelite were detected. It's also indifferent to the channel paid or free status.
I have that same problem today on 2.0.0.8 . Problem is gone when i instal 2.0.0.7
freestat
